is it my rca cables?
http://www.testfreaks.com/car-amplifiers/jbl-bp1200-1/
well i've had it for years and when i first got it and had this problem i solved it for a couple of years, which makes me think if it were the cables themselves they wouldn't have started shorting out and worked fine for a few years...
is there a fix for the inputs on the amp or am i pretty much looking at buying a new one?
the bp has 2 sets of rca inputs, front and rear. both will do the same thing
so swap it from what its on to the other. (ie if they are plugged into front, move them to rear)
anyone know how many feet of rca cable i should buy to run from the very back wall of the trunk, down the driver's side of the car to the head unit is? it's been years since i did this so i really don't remember. 17ft?
actually i had a relatively cheap pair of rca cables in my house from when i did my install. i decided to run those as a test pair and see if i got noise through them, which i did not. they sounded just as good as the more expensive RCA cables that had just quit on me. so i decided to use them and now all is good.
my rca's run on the opposite side of the car from my power wire, so i don't have problems with interference even with cheaper RCA cables.
the problem was that one of the cables on the RCA cables just didn't work. so no matter what channel you plugged it into on the amp, no signal would come out of it. the other cable worked just fine.
