Alpine SPS-600 6-1/2"
Will these work for the camaro coupes?? I want to replace the ones in the doors only.. Everyone says to use component speakers. But I was wondering, If I can get these will they work okay I mean better than the stock trash ones.??
Last edited by WhiteBird00; 12-22-2009 at 01:26 PM. Reason: Non-sponsor link removed
Ungrounded Moderator
You can make them work but they won't work as well as components. The system is already wired for separate mid and tweeter so installing regular speakers eliminates one of the two channels going to each door from the amp... cutting your output power in half.
EDIT: of course, if you modify the speaker to separate the tweeter and woofer as two channels then they become components and will work much better.
You can just wire them to the stock woofer wires which are full-range, but you'll be missing out on a little bit of power. It won't be significant, though. Bi-amping is not as efficient as many people seem to think. It only really works well when you have a speaker with multiple woofers that are driven separately. Wiring to the woofer wires will use the capacitor that comes with the speakers, which is not a very good crossover, but it's probably better than the capacitor of a different value that the Monsoon system uses. Crossovers are more important than speakers.
You can with some coaxial speakers. When you look at the terminals on the speakers you will see small wires soldered to them. Those wires connect to the tweeter mounted in the middle of the speaker. If you cut those wires and connect them to a separate input, you essentially convert the coax into components. There's not much room to work there so some coax speakers are easier to convert than others. The result will not be as good as true components but the modification can be useful in situations like the door speakers in Camaro Monsoon systems.
Okay guys I finish the install on the speakers and they sound good this what I installed over the last two days. I first installed the HU.. Then moved on to the 4" in the hatch, from there I went to the doors. I didn't do the mod to get components from the speakers I just wired them to mid woofer and they sound way better than the stock.. Feel free to ask Questions... Enjoy..
I didn't want to mess up the speaker and be **** outta luck... LOL... That's why I didn't do the mod..
