? about speakers
Old Feb 15, 2010 | 02:56 PM
98z8uup's Avatar
Default ? about speakers
What is the deference component speakers, and coxical speakers. Also can you tell them apart just by looking at them. I ask because people say use components for the doors, and coxical for the sails.
Old Feb 15, 2010 | 04:44 PM
95BlkBird's Avatar
Coaxials have the mid with the tweeter built into it. Components have a mid bass driver, tweeter and crossover all seperate usually. Ppl use Coaxials in the sail because everythings built in one i would imagine.
Old Feb 15, 2010 | 05:30 PM
98z8uup's Avatar
Thanks 95BlkBird
Old Feb 15, 2010 | 07:35 PM
99Bluz28's Avatar
Most(low-end) coaxial speakers have a very low quality x-over mounted right on the speaker frame and as a result the sound quality of the speakers is usually less then ideal. On the other hand, many of the "high-end" coaxial speakers have a separate hight quality x-over and producer a smoother sound. So you can still get a good sounding coaxial speaker, and some component speaker systems give you the option to mount the tweeters coaxial fashion.
Old Feb 15, 2010 | 08:15 PM
WhiteBird00's Avatar
Ungrounded Moderator
Nobody who knows anything about Monsoon systems ever recommends putting coaxial speakers (or even components for that matter) in the sail panels. The Monsoon amp provides only low frequency signal to the sail panels so you need subs or mid-bass there unless you rewire.
Old Feb 15, 2010 | 10:01 PM
99Bluz28's Avatar
Cool
Who said anything about the monsoon systems?
Old Feb 16, 2010 | 07:02 AM
98z8uup's Avatar
Look for some good speakers. Not for a monsoon systems.
Old Feb 16, 2010 | 07:23 AM
The OP didn't specify what kind of system and since the vast majority of Z/28s and T/As have Monsoon systems, the response seemed appropriate.
Old Feb 16, 2010 | 01:44 PM
99Bluz28's Avatar
Smile
Very true, but now we know what he was really talking about.
Old Feb 16, 2010 | 03:52 PM
98z8uup's Avatar
I have a set for the sails just need a good seet for the doors without breaking the bank. I am getting a 5 channel CADENCE amp from KEE AUDIO.
Old Feb 16, 2010 | 07:01 PM
99Bluz28's Avatar
If your going with component speakers, do you know where your going to mount the tweeters?
BTW, what's your budget?
Old Feb 17, 2010 | 06:51 AM
98z8uup's Avatar
If I do go with the component. Where is a good place to mount them in Camaro. Don't want to spend no more than $120.00 to $130.00.
Old Feb 17, 2010 | 11:32 AM
99Bluz28's Avatar
Thumbs up
Here's where I mounted mine. with the aid of a hole saw, and some trimming on the back side of the door panel with a dremel.
A set of Polk db components are good sounding speakers, and within your budget.
Last edited by WhiteBird00; Feb 17, 2010 at 11:40 AM. Reason: removed non-sponsor link
Old Feb 17, 2010 | 02:48 PM
98z8uup's Avatar
^^^^^^^ Thats a nice clean install. Thanks alot.
