160 or 200
Old Feb 25, 2010 | 04:51 PM
jam99's Avatar
Default 160 or 200
I have a 550 watt amp and a new alternator pulley and a underdrive pulley too. I need to know what alternator i need a 160 or 200 amp. HELP!
Old Feb 25, 2010 | 06:16 PM
HaulinHawk's Avatar
Search the "big 3 upgrade" might be what u need.If u still need an alt a 180 should be more than enough.Ws6 store i believe carries a good brand alt now i believe.BTW a alt wont get u into the 11's,LOL!!!!
Old Feb 25, 2010 | 07:10 PM
99Bluz28's Avatar
Is the alternator pulley an overdrive, or underdrive ?
Old Feb 25, 2010 | 07:33 PM
Cameron-95LT1's Avatar
You should easily be fine with the stock 105 amp alt and big 3. 105 amps x 13v is 1365 amps
if that amp is anywhere near efficient you wont have a problem at all
Old Feb 26, 2010 | 04:57 PM
jam99's Avatar
I believe they are both underdrive.
Old Feb 26, 2010 | 05:07 PM
jam99's Avatar
Ha Ha, closer than you were mod for mod. I think by like 4tenths. WHAT! LOL. At lease i could probably make it down the track without a granade going off in my tranny. I did check out some stuff on the big 3, and i might do that in addition to a larger alt. Might as well.
Old Feb 26, 2010 | 06:19 PM
Mike454SS's Avatar
I've been perfectly fine with a stock alternator, and stock cables (really clean and well maintained though). My sub amp is 400 watts, and my front components are 150 per channel...I never see any voltage drops and never have any electrical issues when the stereo is cranked.
The pulleys are 1 under 1 over...you underdrive the crank pulley to lose less power to the power steering pump and water pump, but the you overdrive the alternator so the car will still charge the battery at idle.
Old Feb 26, 2010 | 08:03 PM
bigj2717's Avatar
I used my stock one with 2 amps totaling 1600 watts rms and it was fine. I just added a capacitor and a good battery
Old Feb 26, 2010 | 08:29 PM
HaulinHawk's Avatar
Do the big 3,see if that solves ur prob.If not then get a new stock alt or up it to a 160.
Old Feb 26, 2010 | 09:25 PM
cfallsguy's Avatar
As has been said, you should be fine without an alt upgrade. I'm running 1200+ watts on stock alt and my voltage only slightly drops if the systems full tilt at night with all my lights on.
Old Feb 27, 2010 | 07:14 PM
dragonrage's Avatar
Underdrive crank pulled and underdrive alt. pulley = stupid.
Old Mar 1, 2010 | 04:47 PM
Koncrete's Avatar
I only have 1,500 watts and if I really decide to crank it up I can almost cause my engine to stall out...
Old Mar 1, 2010 | 05:03 PM
trx250r's Avatar
^^^check your ground out make sure its in a good spot with good contact. Battery could be getting worn out, amps are hard on them.
Old Mar 1, 2010 | 06:58 PM
dragonrage's Avatar
Your amps should hardly be touching your battery while driving the car. Your alternator is supposed to be able to handle the load.
Old Mar 1, 2010 | 11:27 PM
cfallsguy's Avatar
x2. The battery should only be affected if your running the system with the car off, when the cars on the alt. powers what it can, but overloading it with too much power can cause it to fail. <1100w should be fine on the alt, anything over can potentially strain it and thats when an upgrade would be needed.
Old Mar 2, 2010 | 04:02 PM
Koncrete's Avatar
Ideally yes, but our cars are pretty electrically challanged... I'd be interested to find out what the electrical load of driving is... ECM/BCM/Engine/Lights/Monsoon Stereo.... I could see all that using most of the available power from the little alt that's on these... Add on a RE35.1D and you can see why I am dimnming so much...
Old Mar 4, 2010 | 05:54 PM
98camaro28's Avatar
You don't need an alt, a cap, or a battery. The big 3 is the only thing you're going to benefit from with your system being as small as it is.
