Kee Audio or no? help please
Thanks guys for the kind words!!
The 10 speaker system in your 1995 Firebird sounds like it is the early version of the Monsoon system. It is similar but has the amp on the passenger side sail panel by the seat I believe. The basic/standard package would still work well with your situation and be better then stock.
There were several different audio systems in these cars from 1993-2002 even though the interiors were essentially the same. It can be very confusing.
My shipment will be here Tuesday though so no problem. Plus I have another one coming after that.I will also be getting you some pictures of how they look installed in your stock plastic mount with the rear showing how they are wired. It should give you a better idea of what your looking at when you install them.
