Sub /Amp suggestions
Old Mar 11, 2010 | 03:40 PM
Red97LT1's Avatar
Default Sub /Amp suggestions
Got the stealth box and Now I need a sub and an amp.I have been recommended these.
(1) Image Dynamics IDQ 10 v.2 or v.3
(2) RE SE-10
(3) Alpine Type-R
Depending on which sub I go with,what amp would you say would be a good pairing.Thanks
Old Mar 11, 2010 | 03:42 PM
dilatedpeoples28's Avatar
(2) RE SE-10
(3) Alpine Type-R
from personal experience I can tell you the RE SE-10 is an awesome sub. It can take a beating, and it sounds outstanding doing it. I would either go with the Image Dynamics or RE if in your position.
Old Mar 11, 2010 | 04:18 PM
Red97LT1's Avatar
I don't really have a local audio store to listen to any of these,so I need all the help I can get. I listen to all sorts of music,rock,metal,rap,etc.
Old Mar 11, 2010 | 06:05 PM
TZ2884's Avatar
The arc ARC10 would be a good choice too. They are similar to the I D and work well in small sealed boxes, they're very versatile. If you're looking for an amp to pair one with I would use the ks500.1 or the ks300.2 both are extremely clean amps. Arc also has a ks mini series that's very small but powerful, check out the ks500.1mini too. Just a suggestion. Out of the three subs you named I like the I D.
Old Mar 11, 2010 | 06:07 PM
collier341's Avatar
RE SE-10
I've heard nothing but outstanding quality and insane power from RE.
For the price you can't go wrong with Kicker either.
Old Mar 11, 2010 | 06:26 PM
TZ2884's Avatar
The only problem I've ever had with re is customer service. But remember that is very important when it comes to warranty issues. I haven't dealt with the company in a few years though, things might be better now.
Old Mar 11, 2010 | 06:34 PM
b.lee's Avatar
I guess I'm bias but kicker, mtx or memphis audio would be my choices.
Old Mar 11, 2010 | 06:41 PM
thaar's Avatar
Fi Q does great in small enclosures. If Ian at Kee chimes in, he may suggest the CDT QES line. I'm still torn between these two for my car. One of these days I'll make a decision...
Old Mar 11, 2010 | 06:42 PM
thaar's Avatar
And there are so many great options for amps. Your budget will help determine that for sure, as will how much power your sub will require. Are you planning on having the amp dedicated to your sub, or run your whole system off of it?
Old Mar 11, 2010 | 07:24 PM
KEE AUDIO's Avatar
All above mentioned are nice. I've also used the RE Audio SE10...great sub. I like the Fi and the CDT but those are MUCH pricier subwoofers.
Also now have MMATS which are in the same performance level and price as the RE Audio. Plus they have very nice amps as well. Some stable down to .5ohms...yes a half ohm stable amp.
Kicker and MTX don't hold a candle to CDT, MATTS, ID, Fi, and several others mentioned. The Type-R is somewhere in between those mentioned and the MTX/Kickers. I would not say it is a bad subwoofer by no means, it is a good performing sub but compared to the performance level of some of the others...
Old Mar 11, 2010 | 07:57 PM
Red97LT1's Avatar
So the SE-10 in your opinion would be a better sounding sub than the Type-R? I don't need the neighbors 5 miles away to hear me,but wouldn't mind rattling the doors every once and awhile. Which MMAT sub was you referring to?
Old Mar 11, 2010 | 08:16 PM
Cameron-95LT1's Avatar
Re se hands down
Old Mar 11, 2010 | 08:20 PM
Red97LT1's Avatar
Thanks guys,looks like the SE-10 it is.Now what about an amp?
Old Mar 11, 2010 | 08:27 PM
http://cgi.ebay.com/MEMPHIS-AUDIO-16...34536601262208
Old Mar 11, 2010 | 08:29 PM
thaar's Avatar
Depends on your budget. If you're not looking to spend a lot, check out MB Quarts DSC line of amps. If budget isn't much of a concern and you're looking for a great amp, I would check out JL's HD series or Alpine PDX series of amps.
Old Mar 11, 2010 | 08:42 PM
Red97LT1's Avatar
Was looking at keeping it around the 150-180 mark.
Old Mar 11, 2010 | 09:07 PM
thaar's Avatar
I'd take a look at the MB Quart DSC line then. Great amps for the price.
Edit:http://www.woofersetc.com/p6835/DSC1...-Amplifier.htm $199 will give you 500w for the RE
Old Mar 11, 2010 | 09:12 PM
thaar's Avatar
Here's another good choice: http://www.woofersetc.com/p453/R80;1...0-Watt-Amp.htm $179
I'm not sure how good PG amps are anymore. I used to run their ZX series amps faithfully years ago and they were great, but I've heard their amps aren't what they used to be. Though I can't imagine you can go wrong with it.
Old Mar 12, 2010 | 06:52 PM
Red97LT1's Avatar
Thanks guys.Much appreciated. Looks like I'm going with the SE and The mb quart
Old Mar 13, 2010 | 08:34 PM
Red97LT1's Avatar
What about this? http://cgi.ebay.com/MB-QUART-DSC2150...item53dc08b286 I could get a D2 and wire it to a 4ohm and get 600rms?
