4 12s speaker box
Old Mar 20, 2010 | 01:06 AM
jbigdawg79's Avatar
Default 4 12s speaker box
im looking for a speaker box for 4 12 inch woofers will pay for shipping
Old Mar 20, 2010 | 06:51 AM
TireSm0ke's Avatar
4 12's? Ive never seen a box for 4 subs for an fbody, the only way you would be able to do it is if you fiberglassed an enclosure, and even then I dont know where you could fit 4 12s unless you build a box for the backseats.
Old Mar 20, 2010 | 10:26 AM
cfallsguy's Avatar
You'll have to have one custom made or make one yourself, and its taking on a semi difficult project building the right box with the right port area. It has been done though.
Check out the link: http://www.cardomain.com/ride/3375204
Hope you know what would be required to run that much power and how to properly do it.
Old Mar 21, 2010 | 02:33 AM
98camaro28's Avatar
You will NOT have enough room to build a ported box that will sound half decent. You will have to go sealed. I had 3 12's for a long time in a box I made, and it takes a little modification for that. 2 12's in a ported box will be just as loud, and not rattle the car to pieces like a sealed one would.
Old Mar 21, 2010 | 04:53 AM
meine96ws6's Avatar
really? i can see for maybe a show car.. but, honestly my 2/ 12'' made a ton of sound.. like over 144 dbs.. you can't drive around beating that hard.. either your ears will start so suck.. or the police will get you..
Old Mar 21, 2010 | 05:03 AM
jbigdawg79's Avatar
Default 12s
its just i had that same set up in my old ta i had 4 12s across the back and i still have everything but the box the box was shaped in a w shape and the amps were mounted on top on the flat area the bottom of the box fit right down in the hole in the back of the trunk i didnt know how rare those boxes were and i didnt think i was getting another fbody
Old Mar 21, 2010 | 10:40 AM
cfallsguy's Avatar
Any pics of old setup? Doesn't seem like 4 12's in the hatch would have enough airspace.
Old Mar 21, 2010 | 10:46 AM
dragonrage's Avatar
If you want crazy sound then just get one TC Sounds/Audiopulse LMS Ultra.
Old Mar 21, 2010 | 10:55 AM
cfallsguy's Avatar
Ha, TC Sounds subs are ridiculously expensive and can get subs just as good for cheaper. But it sounds like he's got the whole setup minus the box, but he'll have to make the box since no one manufactures a custom four 12's box.
Old Mar 21, 2010 | 10:57 AM
dragonrage's Avatar
Name me a production subwoofer as awesome as the LMS Ultra that can also be put in a small box... for ANY price. It has something like 38mm of ONE-WAY, LINEAR Xmax. If the guy wants to put 4 lower quality subwoofers like Type R in there, then he's welcome to, but that's just bad, IMO. You'll be wasting so much space and adding so much more weight, and Type R doesn't even have great sound quality.
