New Kit for the Birds
This thread also shows how I addressed the connector and made a direct connection. (without the adapter)
https://ls1tech.com/forums/stereo-el...ht-option.html
I need to replace my passenger side headlight motor, so my question is can I get these LMC Truck housings, get a DDM Tuning 6000K HID Kit, and have it all work in sync, (flip the switch on, lights flip up, lights stay up, lights come on, lights stay on, when I flip switch off, lights turn off, lights stay off, lights flip down, lights stay down) WITHOUT having to splice the DDM kit into the new headlight motor to supply power to everything to work??? Any help on this issue would be appreciated.
And to help anyone understand how the ledgauges kit is setup to work and to see what I'm talking about click on this link http://www.ledgauges.com/firebirdguide.html and read the installation guide, maybe once you see it, it'll make more sense.
Thanks guys,
THE F-BODY KING
U.S. ARMY
If you guys upgrade housings look at running an HIR bulb. They are the brightest halogen you can go with. Also, upgrading your factory wiring harness as this alone will improve even your OE lighting output, let alone an upgraded system.
This is what I did for my prior F-body, 93 Z28:
Thread here:
https://ls1tech.com/forums/appearanc...installed.html
Comes with everything you need, any K headlight you want, you'll just need to find housings for them
So does anybody know where to find some that are preferrably black?
This thread shows how to crimp the proper connectors and seals on the factory wires so we can skip the adapter that comes with the kits. https://ls1tech.com/forums/stereo-el...ht-option.html
I think you talked me into them. Going to be ordering soon.
