subwoofer wiring ?
subwoofer wiring ?
Hey I have a rockford fosgate 10" dual 2 ohm sub going to a rockford 500W amp. I called the company I bought the sub from and the tech guy said to run a wire from the positive from one side of the sub to the negative to the other side. Then run the unused jacks to the amp. I did that and it doesnt seem to be working, the amp has power and everything hooked up from the radio to the amp is correct. Im not sure if the tech guy was confused cuz wouldnt jumping the positive to the negative bump up the ohms to 4 and not 2. I was wonder should I try to run positive from one side to positive to the other and same with the negative. Any help you be great thanks
on a dual 2 Ohm sub you can only run on one channel 4Ohm or 1 Ohm.
check out this link http://www.the12volt.com/caraudio/wo...1&I=22#results
there are 2 2ohm positive and 2 negative terminals on the amp. would it be better to do the 4ohm load set up. And if I did do that would I run 2 wires the the postive side of the sub and each one would go to one of the 2ohm terminals and do the same for negative.
you would run the positive of 1 voice coil to the amp and the negative of the other voice coil to your amp then jump the left over to each other. Follow the posted link for a graphic. Doing this would give you the 4 Ohm load. I would not do the 1 Ohm load unless you know for sure your amp can handle it.
The idea is that current (signal) flows from the positive on the amp to the positive on the first voice coil, out through the negative to the second voice coil positive, and finally back to the amp from the negative of the second voice coil.
