buzz or humm coming from driver side speaker when running
Old Sep 9, 2010 | 01:11 AM
nastyiroc's Avatar
Default buzz or humm coming from driver side speaker when running
Just replaced the speakers with alpine fronts and connected all four wires 2 to the mid bass and the other two to the tweeter. Just wondering what could be causing this.
Old Sep 9, 2010 | 09:10 AM
WhiteBird00's Avatar
Ungrounded Moderator
Were the Alpine speakers components or coaxials? If coaxials, you can't connect the separate pairs of wires designed for components to them without modifying the speakers. If you did connect them without modifying the speaker then you're basically bridging channels on the Monsoon amp which isn't bridgeable. Turn up the volume and watch all the smoke come out of the amp. (Once you let all the smoke out of an electronic device, it won't work anymore.)
Old Sep 13, 2010 | 10:48 AM
nastyiroc's Avatar
What do you mean without modifying the speakers? I put the pos to the pos for the tweeter and the negative to the negative for the tweeter and same for the mid bass. I don't see why that wouldn't work. Please advise me on what to do different or what speakers to buy. Thanks
Old Sep 13, 2010 | 11:01 AM
SparksAI's Avatar
If it is a coaxial you should not connect all four wires to the speaker because the tweeter and the mid are wired together on the speaker. By doing this you basically connected two channels to a single speaker. To modify it you would need to disconnect the tweeter positive and negative from the mid driver. That can be a hairy route to go. If you are going to use the stock amp you will want to go with a set of component speakers and connect them seperately.
Old Sep 13, 2010 | 11:35 AM
nastyiroc's Avatar
What speakers would you suggest I use. I want to put them in the factory location and do not want to mount a tweeter anywhere else but in the factory spot.
Old Sep 13, 2010 | 11:37 AM
nastyiroc's Avatar
I cut the tweeter wires off the main 2 pos and negative and wired it that way. Should it still be humming when the engine is running
Old Sep 13, 2010 | 11:52 AM
nastyiroc's Avatar
Could this have anything to do with it also?
https://ls1tech.com/forums/stereo-el...o-speaker.html
Old Sep 13, 2010 | 12:26 PM
SparksAI's Avatar
There is a factory tweeter and seperate mid-driver. Most people that install components to replace the factory ones use the factory mounting spots for both so no new holes need to be cut. As far as the buzz it could be a ground loop, have you changed anything other than the speakers in the system? If you reconnect the stock speakers does the buzz go away?
Old Sep 13, 2010 | 01:37 PM
nastyiroc's Avatar
Im just wondering if in the speaker wires is there suppose to be some kind of resistor or filter that maybe was cut off? I got the car without any speakers. And I put in an aftermarket jvc headunit too but it only seems to be happening on the drivers side.
Old Sep 13, 2010 | 01:38 PM
That depends... Camaro or Firebird? If Firebird then yes, it is possible that the inline filter could cause a humming or buzzing noise. If it's a Camaro then no, there is no inline filter - the Camaro tweeters are powered by the Monsoon amp which has filtering built in.
However, I agree with SparksAI... it sounds like a possible ground loop problem.
Old Sep 13, 2010 | 01:52 PM
SparksAI's Avatar
Since you did the head unit at the same time I would look there first. electronics are kinda funny that way. Only certain channels can pick up ground loops and others wont, it really depends on how the internals are designed. Is the buzz only when the car is on or does it matter?
Old Sep 13, 2010 | 07:30 PM
nastyiroc's Avatar
the buzz only seems to be when the car is on
Old Sep 13, 2010 | 08:32 PM
SparksAI's Avatar
Yeah you have yourself a ground loop. When you installed the head unit do you just use a harness adapter or did you ground the headunit somewhere else?
You are going to need to change the location of the ground. If you or a friend has a multimeter set it to read dc voltage and turn the car on. Holding the ground probe to the negative of your stereo, touch the positive probe to various areas and bolts under the dash. Try to find a place that has a reading of 0 volts. Ground there. If you don't have a multimeter it gets a bit harder and you might have to do a little trial and error, just groung it somewhere then turn the car on, does it make noise? yes then move the ground, no then stick and forget it. Good luck to you. Ground loops suck but I think you can fix this with little worry.
Old Sep 14, 2010 | 12:11 AM
nastyiroc's Avatar
I just used the ground on the harness
Old Apr 18, 2011 | 04:13 PM
nastyiroc's Avatar
It's still doing it grrrrr any fixes?
Old Apr 18, 2011 | 05:31 PM
Capricio's Avatar
Maybe describe your efforts at re-grounding first? Sparks's and WB's advice seemed pretty solid. What did you try since their posting?
Old Apr 20, 2011 | 12:58 PM
nastyiroc's Avatar
Is there any way I could get a oem pig tail for the connector that the speaker plugs into?
Old Apr 26, 2011 | 05:11 PM
nastyiroc's Avatar
It still hums even with the headunit turned off......
