Need to buy an HO alternator...
) so please tell me where I can find one!! It went right in. I used the stock belt for a couple of days, but I didn't like how tight the belt was and didn't want to cause damage to the bearings so I went to Autozone and bought a belt 10mm bigger. I forget the number at the moment but our belts are 6 rib, so the part number is the the number of ribs + the diameter or length of the belt, so I just did some math while playing around on their website.
The AD244 is rated at 145A, but actually puts out closer to 200A (100A at idle), where the stock alternator is something like 45A at idle (105A rated)
coming from personal experience with 1,500+ watts/my 2 cents.
1. Sparks knows damned well what he is talking about and there is a reason that the entire (okay like 99.99569%) community of serious stereo guys go with the big 3. Because it works. Here is the wire size difference. Yes, those are all of the 3 original wires next to a 1/0.
2. If it is okay to post it, do a search for "160 alternator camaro" on ebay. There are a ton and they range from $104 to about $140 shipped.
Again there is nothing wrong with upgrading the alternator first. Honestly the best plan of attack is just to do all three upgrades at the same time. What I mentioned is purely my preferred route. When you start to see headlights dimming and such a big three is going to fix the problem 99% of the time. As someone pointed out earlier the size difference in the wire shows you why this upgrade works. It is like the plumbing in your house, sometimes when people introduce a temporary load on the cold water a person taking a shower will only get hot water, why because there isn't enough supply to meet demand. A higher guage wire helps to give you that supply.
As I said the alternator will help you out with your issue. If you want to replace it go for it. There isn't anything wrong with having extra piece of mind. I think the thing people are trying to help you out with here is just to try the Big three first and see how it goes. From there a battery or alternator or both is up to you.
I was under the impression that at low RPMs, higher power alternators churn out less power than stock. Is that misinformation that I picked up somewhere, or is there merit to it?
Thanks!
