trunk randomly opens?
Old Nov 1, 2010 | 07:09 PM
xRelapse13's Avatar
Default trunk randomly opens?
Have a problem recently where the hatch will randomly pop itself when i'm driving, if the car is sitting off etc... If i'm driving sometimes it just pops, if I have it parked it will pop sometimes which sets off the alarm. Tried disconnecting the switch on the knee panel and it did the same thing. I have the mechanism in the hatch disconnected right now since it's a dd and I can't afford to have it randomly opening. Any ideas?
Old Nov 1, 2010 | 07:19 PM
bad_408_vert's Avatar
Are you having the usual problems when the BCM goes bad. Typically your windows and radio start having problems.
Old Nov 1, 2010 | 09:09 PM
xRelapse13's Avatar
That's the interesting thing. Radio and windows have been working perfectly and i've had no problems that would be associated with bad BCM
Old Nov 2, 2010 | 06:31 AM
wssix99's Avatar
Save the manuals!
What kind of transmission do you have?
Old Nov 2, 2010 | 09:55 AM
xRelapse13's Avatar
6 speed
Old Nov 2, 2010 | 03:04 PM
wssix99's Avatar
Save the manuals!
The BCM should keep the hatch from popping when you are driving and your emergency brake is off. (For a 6 speed.) So, if your BRAKE light is off, and your hatch pops while you are driving, I'd say that you probably have a short in the wiring that's causing the latch to pop. (In other words, the BCM/button isn't sending the command.)
Have you done any wiring in the car or gotten in any accidents?
Old Nov 27, 2010 | 09:57 AM
xRelapse13's Avatar
No accidents, although the brake light is on a good amount while driving since the abs inop light is also on due to something not right in the abs system.
Old Nov 27, 2010 | 01:46 PM
Fosnot's Avatar
The ABS might be solved by replacing the brake switch thats connected to the brake pedal, same thing happened to my old Z28, real quick fix.
The brake light on your dash should be fixed my replacing the e-brake switch in the center console.
Both aren't that hard to do, just a little time consuming because of their location.
Old Nov 27, 2010 | 02:26 PM
xRelapse13's Avatar
ooh, I was actually assuming the two were related and that the brake light was on due to the abs inop. As in a "brake system" "abs inop".
Where is ebrake switch in the center console?
Old Nov 28, 2010 | 10:43 AM
wssix99's Avatar
Save the manuals!
No!!! The answer is probably above. On the manual transmission, the e-brake handle is part of the logic that allows the hatch to pop.
The "BRAKE" light illuminates for several different reasons. One of them is when the e-brake is on.
If you e-brake is truly off, then the e-brake switch (on the handle mechanism) is probably bad. (This is a common problem.) The car "thinks" the e-brake is on as a result and you are probably brushing against the hatch release button or hitting a bump, etc. and the BCM "thinks" its OK to pop the hatch in that situation.
Old Nov 28, 2010 | 07:09 PM
xRelapse13's Avatar
Definitely wasn't an accidental brush against the button. Since even with the car parked and off the hatch would randomly pop.
Brake and ABS INOP come on at the same time when ever they do come on.
Old Nov 29, 2010 | 08:54 PM
wssix99's Avatar
Save the manuals!
Before you go chasing ghosts, you should probably check the e-brake switch, just for kicks. It just takes the time required to take the center console out and can be done with a simple continuity tester. If that switch is good, then you must have a short in the circuit between the BCM and the trunk release or a bad latch mechanism.
Old Dec 18, 2010 | 06:44 AM
mxmccarter2401's Avatar
My 98 does this too. I dont know what the deel us. Good luck,Subscribing
