Front Door Speakers
The JBL's need a slight mod, like the Infinity's to wire up to the stock system. The CDT's wire up exactly like stock and do not need to be modded.
https://ls1tech.com/forums/stereo-el...t-monsoon.html
As I stated in that particular thread, I have some coaxials that are better for this mod then others that actually have the tweeter wires running up the rear magnet on the speaker so that you don't have the wires running in front of it.
I also have the speakers I use in the packages that are made like the stock ones in that they are already wired separately but can be mounted coaxially like stock.
Hope that helps! The Monsoon system can get kind of complicated but it can be modded and sound good when done correctly.
Memphis does make a quality product though and the M Class Memphis product line is about the same quality, price and sound as the JBL Power Series when heard side by side. They even share the same honeycomb core cone. The Memphis is a slight bit brighter though using a metal tweeter vs. the textile dome tweeter which is a little less bright.
Neither are quite as good as the CDT though for overall sound quality.
