Visually appealing 3.5mm panel mounted jack?
Old Jan 5, 2011 | 12:29 PM
1SLwLS1's Avatar
Default Visually appealing 3.5mm panel mounted jack?
I bought the USA spec for my T/A about 1.5-2 years ago and was using it with my iPhone up until recently. I switched over to the HTC EVO and can no longer utilize the iPhone wiring so I am using the RCA inputs on the USA spec unit to input audio from my phone to the stock 2002 Monsoon Radio with a 3.5mm cable.
I want to step it up a notch and install a 3.5mm jack into the center console or dash that is aesthetically appealing. After a quick search, the only one's I have seen are the cheap-o solder type with threads that protrude through the panel and an external nut to secure it in place, somewhat of a burden on the eyes. I am looking for something that looks "factory" installed; possibly with a black rubber flange externally and an "ugly" nut securing the unit from the inside, hidden from view.
After hours of searching, this is all I have found and it's a little cheesy at best. Anyone found anything better or am I being unrealistic and too picky?
Old Jan 5, 2011 | 01:13 PM
sherm6998's Avatar
I've been looking at something similar and that is the nicest I've seen. Thanks for posting it. Sorry for not being any help. :-(
Old Jan 5, 2011 | 01:49 PM
1SLwLS1's Avatar
Bummer, hopefully someone else has found something and adds that.
Old Jan 5, 2011 | 05:01 PM
WhiteBird00's Avatar
Ungrounded Moderator
How about this one: http://www.altex.com/35mm-Stereo-Fee...3-P147826.aspx
Old Jan 5, 2011 | 05:23 PM
1SLwLS1's Avatar
That one looks pretty good. Luckily, I have a store with (10) in stock less than 20 miles from home and 5 miles from work. I'll swing by there tomorrow or Friday and check it out. Thanks.
Old Jan 10, 2011 | 11:06 AM
1SLwLS1's Avatar
That one turned out pretty good. I will probably just stick with it unless I stumble upon something nicer that will work with the gigantic 3/8" hole I added to the center console. Let me know what ya'll think.
Old Jan 10, 2011 | 01:07 PM
stealth355tpi's Avatar
I just a hole inside the center console at the bottom with the wire coming out of it. when i need it, i just open the console and pull the wire out. i didnt want a jack that showed on the outside.
Old Jan 10, 2011 | 01:45 PM
1SLwLS1's Avatar
That's what I did with my iPhone and had been doing with the EVO. Now, I have a windshield cradle for the EVO so I can use navigation, data logging, gauges, etc. and to have the wire coming from the center console all the way to the windshield and at the top of the phone, wasn't feasible to me.
