Which of these two amps would you recomend for a Type r 10"
Here are the amps:
Which one would be better for a Type R 10" sub 500RMS-600RMS?
Which one is made with better quality/durability in mind?
If you guys have an amp that you would like to recommend for about the same price or less, please do so!
MRP-M500 for about $150 shipped
Hifonics Hfi1000d about $165 shipped
Thanks
Alpine MRP-M500
* RMS Power @ 4 ohms: 300W x 1 (1% THD)
* RMS Power @ 2 ohms: 500W x 1
* CEA-2006 Power Ratings @ 4 ohms: 300W x 1
* Class-D (Digital) Amplifier Type
* Continuously Adjustable Gain Control
* Dual Sided Glass Epoxy PC Board
* Gold Plated Input, Output, Power and Speaker Terminals
* Gold Plated RCA Input Connectors
* Adjustable Low-Pass Crossover
* Speaker Level Inputs
* Top Mounted Blue LED Power Indicator
* Over-Current, Over-Voltage and Thermal Protection
* STAR Circuitry
* MOSFET Power Supply Design
* Thermal Management Control
* Signal to Noise: 100dBA
* Speaker Impedance: 4 or 2 Ohm
* Frequency Response: 20 -200Hz (200Hz/-3dB)
* Input Sensitivity: 0.2 - 4.0V
* Power Requirements: 14.4V DC (11V to 16V)
Hifonics Hfi1000d 1,000 Watt RMS
* New Hifonics HFI1000D HFi Series 1000W Monoblock Class D Car Amplifier
* RMS Power at 4 ohms: 475 watts x 1 chan.
* RMS Power at 2 ohms: 750 watts x 1 chan.
* RMS Power at 1 ohms: 1000 watts x 1 chan.
* Pulse Width Modulated MOSFET power supply
* Blue military grade PCB board
* High dissipation heat sink design
* HFR-3 remote bass level control included
* Adjustable Bass Boost (45 Hz)
* Blue illuminated retro Hifonics "HF" logo
* Mono Amp Capable of Connecting Multiple Subwoofers
* Preamp RCA Outputs
* RCA Inputs
* Built in System Diagnostics
* 4-Way System Protection Circuitry for Maximum amp Protection
* Dual 12 Gauge Speaker Terminals
* Advance Heat Sink Design for Maximum Heat Dissipation
* Silver nickel-plated RCA level inputs
* Silver nickel-plated screw terminals
* Adjustable Input sensitivity level: 200mV-6V
* Adjustable low-pass filter (30-250 Hz, 24 dB/octave)
* Subsonic filter (15-35 Hz)
* Damping factor: >200
* Frequency response: 15-250 Hz
* Dimensions: 13-1/2"L x 8-13/16"W x 2-7/16"H
* 80A: fuse Rating
* Power and Ground Inputs: 4 Gauge
Thanks
Alpine MRP-M500
* STAR Circuitry
* RCA Inputs
* 80A: fuse Rating
Me personaly, id go with the hifonics. it may not be cea rated power, but its damn close. another thing i look at is fuse ratings. i think the alpine has 2 20amp fuses where as the hifonics has a 80. there for the hifonics should produce more power.
my gf has that alpine amp pusing 2 10" type s's in her truck. sounds good and its a damn powerful little amp. i have a 1600watt hifonics amp pushing a 10" RE audio SX, and it pounds the **** outta that poor little thing. its way over powered. i used to push to 12" type R's with it without a problem.
Latch what type of sub do you have and what's the RMS and Peak wattage?
These are the subs that I'm looking into getting.
type r swr-1022d 500watts RMS 1,500Watts Max
type r swr-1023d 600watts RMS 1,800watts Max
type r swr-1042d 500watts RMS 1,500Watts Max
type r swr-1043d 600watts RMS 1,800watts Max
I've been reading that sub can get damaged if it's underpowered. I'm leaning towards the 1022d or the 1042d (Both 500RMS) However, I was told that the alpine mrp-m500 (500RMS) will supply a Type R with a nice amount of power, but it won't elevate the Type R to it's true potential. I don't want to damage my sub and I want to get the most out of a Type R.
What do you guys say?
Thanks,
Joel
Thanks,
Joel
Kleeborp the Moderator™
The Hifonics looks like it would put out more power but in a slightly larger package (Alpine is 10-11/16"W x 2-7/16"H x 9-9/16"D; Hifonics is 13-1/2"L x 8-13/16"W x 2-7/16"H).
Personally, I am very pleased with that Apline - I use it to push a single 10", 4-ohm DVC Alpine Type R wired for 2 ohms stuffed in a stealth box, and IMO, it sounds very good in my Camaro. I'm sure there are louder setups out there, but this combo gives enough bass that I can actually make it too loud for me, which is all I need. I already managed to **** my wife off by playing it too loud when I was out in the garage - apparently, it was shaking the stuff in the kitchen (the kitchen and the garage share a wall). She got over it
