Mixing off brand crossover with component set
Old Feb 15, 2004 | 12:37 AM
Gregg 00SS's Avatar
Default Mixing off brand crossover with component set
Anyone know how mixing a different brand crossover with a different set of component speakers will effect the quality? Looking at a set of Focal Utopia's, but they come with a Diamond Audio Hex S5.0 crossover. I was planning on going with the Polykevlars, but might be able to get the Utopia's for a decent price because of the mix match, but don't want to do it if I'm gonna give up a lot of sound quality.
Old Feb 15, 2004 | 02:44 PM
maddboost's Avatar
Crossovers are matched to a component set by manufacter. One manufacters frequency range for tweeters may be different than anothers. Same with midranges. This can cause the Tweeter to reproduce frequencies it was not intended for and blow the speakers. Tweeters are very fragile if you send to low of a frequency. I would not buy those speakers if I was you.
Old Feb 15, 2004 | 06:45 PM
you2slo's Avatar
You should never mix and match components and crossovers. Very bad idea.
Old Feb 15, 2004 | 07:57 PM
Zo6Killer's Avatar
I used to have a set of Infinity Kappa 6.5 components with no x-overs. I bought a set of MB Quart Pro x's and they sounded great. I never had it RTA'd or anything, but it sounded pretty damn good. I don't know if this would always apply, but the MB's had various settings on them (ie tweeter attenuation) that I messed with and came out with a great sound.
Old Feb 15, 2004 | 08:03 PM
maddboost's Avatar
The setting on MB Quarts crossovers allow you to raise or lower the DB of the tweeter. But its at a predetermined frequency. It in no way allows you to adjust the crossover points.
Old Feb 15, 2004 | 08:08 PM
Zo6Killer's Avatar
And I believe that is known as "attenuation". Like I said, it might not work for everyone, but mine sounded really good.
Old Feb 15, 2004 | 08:44 PM
maddboost's Avatar
I dont try to use big words it just makes most people feel stupid. I was a saleman of high end car audio so I know how to "Dumb down" car audio stuff so everyone can understand.
Old Feb 15, 2004 | 10:39 PM
F8L Z71's Avatar
12 Second Truck Club
Ditto
Technically attenuation is the reduction of or weaking of a force or value. In some X-over networks you have the ability to increase the DB on a tweeter so the word attenuation would be applicable.
Ok, that was dumb. Seriously though. You can get away with using a different X-over network on a set of speakers but like madboost stated it is generally not a good idea unless you know where the filters are set and/or if the components are of similar style and size IE. the x-over networks were set to run 5.25"s and titanium tweeters as opposed to 6.5"s and silk domes...
But if damage occurs you have no one to blame
Simply check with Diamond Audio where their X-overs are set and then check with Focal and see where they recomend x'ing over thier mids/highs at and if all matches up close enough go for it
