correcting the coolabnt gague
Old Jul 24, 2005 | 04:29 AM
Jpr5690's Avatar
so your saying just replace the sender unit?
Old Jul 24, 2005 | 04:30 AM
Jpr5690's Avatar
id like to see if that works...
Old Jul 24, 2005 | 02:37 PM
CRL 01 SS's Avatar
Yeah, just replace the GM sender with an Autometer sender. The Autometer sender's threads are smaller than the GM sender's threads so you'll need a reducer fitting to make it snug.
Old Jul 24, 2005 | 05:02 PM
Jpr5690's Avatar
u gotta be kidding me ...no f*in way thats it if so man you just solved a long long standing questiion.. can anyone else verify this .. also where is the sender located ?
Old Jul 24, 2005 | 05:07 PM
Jpr5690's Avatar
what sender did you use i just went to the autometer site and theres tons of different senders for the different types of temp gauges
Old Jul 24, 2005 | 06:03 PM
CRL 01 SS's Avatar
I used the sender unit that came with my electrical Autometer Sport Comp water temp gauge. Don't know the exact part # for the sender. The water temp sender is located on the side of the drivers side head, towards the front.
Old Jul 25, 2005 | 12:20 AM
Jpr5690's Avatar
dam and your sure your gauge reads accurate and not just a different temp all the time.. i mean does it fluctuate like it should or does it just go up to 180 and sit there?
Old Jul 25, 2005 | 12:24 AM
Jpr5690's Avatar
and was the gauge the sport comp model that had a range 0-250 and was a short sweep electric ...if so its pn 2258..
Old Jul 25, 2005 | 12:48 AM
Jpr5690's Avatar
was this what it looked like if it is i noticed that the sport comp gauges are 0-250 range while the stock is 0-260 range.. but my big big question is again does the gauge respond to temp changes or does it just sit at 180 deg all day long instead of 210
Old Jul 25, 2005 | 08:46 AM
jimmyblue's Avatar
Moderator
I read (I think in the Helm books) that the PCM jacks
around with the sender force current or voltage, and
at some point when it's semi-hot it changes the drive
abruptly (I presume for more temp accuracy where it
counts).
If the sender is used for a standalone gauge then it
ought to work fine. But tapping off one that's PCM-
driven might have some weirdness? Do you use a
different hole and a second sender for the standalone
gauge?
Old Jul 25, 2005 | 11:31 AM
Jpr5690's Avatar
no replaced his stock sender with an aftermarket one and now he says hes getting accurate temp readings
Old Jul 25, 2005 | 11:50 AM
  #32
superchannelkev's Avatar
makes sense... sorta, but isnt the factory temp sensor a two wire hook up? Then wouldnt you need to run one wire to the aftermarket sensor and then ground the other one? or did i miss that? i just used a standalone gauge and left it as is... but if this works then maybe i could have a little cleaner set up.. look forward to hearing more on this..
-kevin
Old Jul 25, 2005 | 06:21 PM
  #33
Jpr5690's Avatar
TTT somebody add something .. im trng to get ahold of a 98 temp sensor to try this out i figure if this is true then a sender from a 98 car should do the trick
Old Jul 27, 2005 | 01:55 AM
  #34
Jpr5690's Avatar
i was thinking ... i dont understand how that can work beacouse the stock sensor reads fine if you scan the pcm just he gauge is off if what your saying is true then even when you plugged a scan tool in the car would see 210* which is not the case..
Old Jul 27, 2005 | 07:59 AM
  #35
BLOW ME FASTR's Avatar
Stop trolling the thread
Old Jul 27, 2005 | 09:21 AM
  #36
WhiteBird00's Avatar
Ungrounded Moderator
Changing the sensor won't have the desired effect on the gauge because the gauge is controlled by the PCM. The sendor is a variable resistor that shows lower resistance with higher temperature. The PCM interprets the resistance and sends a Class 2 data signal to the instrument cluster to control the gauge. If the sender is changed then the PCM will still read the resistance as though it was a factory sender and adjust the gauge in the same way. It is possible that the combination of a lower temp thermostat and a different sender would cause the resistance not to reach what the PCM considers the "normal" range so it wouldn't force the 210* reading. That would make it appear to read accurately until the temperature rises enough to reach the "normal" range when the PCM would just fix the gauge at 210*.
The best bet for fixing this "problem" is reprogramming the PCM - if that is a programmable option. Otherwise, a 98 PCM could be installed but I think there were a number of other changes between model years that could cause worse problems.
Old Jul 28, 2005 | 03:39 PM
  #37
CRL 01 SS's Avatar
The factory gauge does fluctuate now that I replaced the sender. From a cold start it works its way up to about 180 or so, and then when I turn it off and let it sit it will work it's way down as the engine temp cools. It doesn't sit on 180 all the time, when it's hot it'll move between 180 and 210. When I flip my fan switches on it moves back down. It think it's probably as accurate as it can get with the factory gauge. If you want it to be perfect buy an aftermarket gauge and plug that sender in somewhere else. I believe there is a place to put it on the passenger side head by the #8 plug. The factory sender is a two wire hook up, the black is the signal wire and the yellow is a ground I believe. When you use the Autometer temp sender you only use the signal wire, no ground is necessary. I could not use the stock gauge and Autometer gauge at the same time when they were both hooked to the sender, so I ditched the Autometer and left the stock gauge hooked up because I had to have it working properly. JPR, it is the sender that came with the Sport Comp 0-250 electric sweep gauge.
Old Jul 28, 2005 | 04:18 PM
  #38
cool i was curious about the grounding.. i have an aftermarket temp gauge right now with the sensor on the pass. head an it only used the 1 wire hook up as well. might just experimet with this tonight
Old Jul 28, 2005 | 06:23 PM
  #39
The factory sensor runs a separate ground wire to the engine block while aftermarket (single pin) units just ground directly through the sensor.
Old Jul 28, 2005 | 08:58 PM
  #40
Jpr5690's Avatar
its my thread.. please dont make dumb comments
