correcting the coolabnt gague
you can't put a 98 cluster in your car, as the fuel level is different. :/
somebody needs to find the code in the gauge cluster, and figure out how to reflash it to be accurate. The cluster receives the correct data, but just registers 210 in the entire "normal" operating range, 186-226 (approx??)
Ryan
My temp gauge works, so i have not bothered doing that kind of extensive testing yet.
Ryan
Ryan.
old post, and you have to be a member of the other site, but it lists the code that is used for the gauge readings. and other info.
I first tried to put my Autometer water temp sensor in place of the stock sensor, and just let the temp gauge on the cluster read 0. This didn't work though because the PCM wasn't getting a signal and it made the car run in warm-up mode the whole time. I tried to wire both gauges up to the Autometer sensor but that didn't work either. So I ended up just hooking the black wire from the factory sensor up to the Autometer sensor and leaving the yellow wire unhooked because it wouldn't run right when both wires were hooked up to the Autometer sensor. It has been wired up like this on my car for about 2 years and I haven't had any problems with it. I don't think running it like this is a bad thing, but somebody who knows more about it might say differently. Maybe this will help.
