DVC coil wiring
Amp specs-
MAX POWER (2 OHM)1000W x 2
RMS POWER (2 OHMS)700W X 2
RMS BRIDGEDPOWER (4 OHMS)1400W X 1
Sub specs-
# Power Range: 600 - 1800 Watts
# RMS Power Handling: 600 Watts
# Peak Power Handling: 1800 Watts
Subs are Alpine Type R's and Amp is a Planet Audio AC2000.2 (probably not putting out the full rated power).
How would I go about wiring the 2 dvc 2 ohm subs to the 2 channel amp at 2 ohms? Or would it be better to run the amp bridged @ 4 ohms? Not sure how to get that either....
You can't make a single 2 Ohm load out of it, unless you get a second identical cone. You can hook up each coil to a channel on the amp, just be SURE to give each channel input on the amp the exact same signal with a splitter, or if there is a "mono" selection on a switch, select that so the amp sums red and white RCA to give each coil the exact same signal.
You do not want to give two voice coils on the same cone a different stereo input. The amp is really overkill for the cone you are using. If there was any practical way to get a second cone in there, it would about right.
1 channel at 0.5-ohms, 1.33-ohms, 2-ohms, 5-ohms, or 8-ohms
2 channels at 1-ohm or 4-ohms each
http://www.the12volt.com/caraudio/wo...igurations.asp
I see the amp is only like $100. I don't know much about Planet Audio, but at that price point I can't imagine it's going to be able to sustain the rated RMS values, especially in a sub application pushing bass through an A/B amp. One option in this case is buy a second identical amp, and have each one drive a cone individually, with 1 channel per coil. This is assuming you have the funds and physical space. Some people will tell you that coils in a DVC should be driven from the same channel but I think as long as you don't mix the inputs it'll be okay.
As far as 5 ohms across a bridged amp, from what I have read, wiring SEPERATE speakers in series (as opposed to the 2 coils on a DVC) is a bad idea, owing to a phenomena called Back EMF (electromagnetic force) causing the speakers to interfere with each other electrically, and cause distortion, and in extreme cases an amplifiers output stage to fail (blow.)
http://www.matrix-audio.co.uk/suppor...e-coil-woofer-
If you can re-purpose the amp you have, I'd say your best option is just get a big class D monoblock. Class D amps really excel producing bass.
I'm ashamed to say I should know since I have a real EE degree, but have been doing IT work for almost 20 years. Most of my audio knowledge is based in Home Theater, too.
Anyways, OP, if you do some reading on damping factor and impedance, you'll find that in general it's better to run with higher impedances and just pony up the dough for a bigger amp to meet your RMS requirements. I just hooked up a kid at work with a couple of 12" CDT HD subs running at 2 Ohms combined load... it smoked the amp (AP10001D). Granted, he was stomping on them constantly, but I think we're going with two smaller class Ds and running them at 4 Ohm next. Low impedance loads (1 and 2 Ohms) are just bad news unless buy a killer amp (JL or RF) for a lot more money than a good cheaper (AP, Pioneer, Kenwood) high powered monoblock at 4 Ohms.
An alternative to 2 Ohms is running two amps at 4 Ohms each. This is fine if the subs are in different enclosures and you don't use a remote volume **** just for the subs. Its less risky than a 2 Ohm load and probably cheaper than an amp that can reliably maintain a 2 Ohm load.
Like I said earlier, running 2 Ohms is fine as long you get a somewhat "overbuilt" amp for it. To me, that means JL, RF, upper end Hifonics, a few others, and beyond that some really pricey stuff (Memphis, etc). Don't want to start a brand war or anything like that. You can pretty much look at the pricing and get what you pay for.
DIYmobileaudio.com is a good resource for product reviews, etc.
