Door panel lights
Old May 24, 2011 | 10:36 PM
Rauch's Avatar
Default Door panel lights
I recently replaced all my interior bulbs with led bulbs to freshen the interior.
However, before I thought he pass side bulb was out. I put the led one in and it nearly blinded me. But when I installed it into the holder in the door panel, barely any light is appearing.
Anyone else ever have the issue? If so, what's the fix? I'm not sure if it's the translucent plastic piece being dirty or what.
Old May 25, 2011 | 11:06 AM
wssix99's Avatar
Save the manuals!
The red lens will reduce the light a bit but there are other things to consider.
If its dirty, you'll see a difference in the performance between your two doors.
What color of LED are you using? LEDs do not produce a balanced light similar to a regular bulb. You should be using a red LED in that application.
A regular bulb produces 7 colors of light and the holder filters that light to only let through the red. If you are using a "white" LED that is heavy towards the blue end of the spectrum, the holder will filter out all of it and barely anything will get through.
Old May 26, 2011 | 05:28 PM
Rauch's Avatar
I'm using the bright white bulbs from superleds or whatever the site is.
The driver side is plenty bright... The Passenger is just almost non existant
Old May 27, 2011 | 08:34 AM
wssix99's Avatar
Save the manuals!
Is the driver side red? Can you post pics? Are you sure they are the same bulbs?
Old May 28, 2011 | 03:04 PM
DaRReLL's Avatar
Same thing happened to me....
WTF!!!
Old May 28, 2011 | 06:02 PM
Elthesh's Avatar
You may have purchased the wrong LED. The LED I used in my doors looks like a tiny circuit board with 3 leds on it. One on the tip, and one on either side of the board. It's bright as all hell at night. I heard the ones with just one LED light were fairly dim in there. Honestly, if the door LEDs were any brighter than they are now, they'd completely distract and annoy me. That's how bright I think they are. 74-xHP3 oh... and, not only that bulb, but you need to use the RED bulbs. As long as you want red that is...
Old May 28, 2011 | 06:54 PM
SparkyJJO's Avatar
My bulbs were just burned out on mine and that was fine with me. The external light on the switches just looked annoying in the pictures I've seen.
I want to find a way to backlight the switches like most newer vehicles... heck the 93 Taurus I used to drive still had backlit switches
Old May 28, 2011 | 09:26 PM
bill12690's Avatar
WTF!!!
odd, i had the same issue. i ended up noticing something slightly different about the pass side if i remember correctly, like inside the holder, theres plastic piece that directs the light and i think that was the issue.. it just didnt seem to direct the light quite as well as the driver side.. i think i put something reflective inside to help, but its been a long time. pretty soon i'll have to replace it though, the LED is going out..
edit: as far as you guys talking about red, keep in mind this isnt a bird...
Old May 29, 2011 | 07:59 PM
DaRReLL's Avatar
I even tried switching the bulbs around.
It currently has that 3 LED bulb in it, one on the top and two on the side.
Old May 30, 2011 | 07:51 PM
Rauch's Avatar
I've went with the white led's. I believe their the 74-xhp's. Can't find my invoice.
Essentially, it's a rectangular bulb with 2-3 LEDs per side. When not in the enclosure they are bright, but put in place the lights almost non existent.
Let me go take some pics real quick. Currently only have net access on my iPhone so uploading them will be interesting.
Brb with pics.
Old May 30, 2011 | 08:53 PM
Rauch's Avatar
Here we go:
Driver side:
Passenger side (Hard to see, but it's the little spec toward the lower left) This is with the bulb through the little hole:
Passenger side out:
Hard to see in the picture but it's like the tip of the clear plastic is not transmitting the light through.
[IMG=http://img41.imageshack.us/img41/905/img0053kyy.jpg][/IMG]
Any ideas?
Old May 30, 2011 | 09:49 PM
whytryz28's Avatar
You have to modify the placement of the LED, compare the location of the driver to the pass. side and you will see what I mean.
Old May 30, 2011 | 10:47 PM
Rauch's Avatar
Hm. So essentially the way it's twisted in?
I'll give that a go in te morning. Only thing is the factory bulb was dong that as well
Old May 31, 2011 | 09:38 AM
wssix99's Avatar
Save the manuals!
Can you post an exact link to the bulb you purchased?
Old May 31, 2011 | 10:54 AM
Rauch's Avatar
Not sure if they're a sponsor or not, so im not going to post. But a quick google of 74-xhp3 should bring them up
Old Jun 1, 2011 | 06:21 PM
wssix99's Avatar
Save the manuals!
Send 'em back for the 74-xhp. The lens in the panel is just a small square, so only the light coming out of the top LED is visible. Is the top LED working in the bulb you are having problems with?
Old Jun 1, 2011 | 08:06 PM
LS1121's Avatar
I had a similar issue with the passenger side not being as bright as the drivers side. Inside the piece the bulb goes into there is a piece of clear plastic that directs the light onto the switches. The clear plastic piece in my passenger side door bezel was clouded so i RIPPED it out and taped the light into the hole. Then I bought another door bezel with a GOOD clear plastic light "deflector" ? and all is well now. Hope this helps.
Old Jun 1, 2011 | 08:21 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The clear plastic pieces people are referring to are waveguides - they are what let the light turn such a tight corner. Unfortunately, they are designed for standard incandescent bulbs, and is why you are having problems...the driver's side works for whatever reason, but the passenger side is dim as hell when the LED is fully seated, regardless of design. I fought this issue a few years ago, and the problem has to deal with the extremely directional nature of LEDs. Unfortunately, the 74 type LEDs are really small, so there aren't many good options to find a suitable LED configuration with a full 360* light pattern. I even tried the 3 LED SMT version referenced in this thread...still didn't work right.
What I ended up doing is finding an LED with a phosphorescent coating that gives a full 360* light pattern, and that ended up working the best, although it required some custom work to fit it properly and keep it fully plug and play (a resistor was required). SuperBrightLEDs sells them...just look under the component LEDs.
Old Jun 2, 2011 | 08:23 AM
MTBSully's Avatar
i have the same issue. drivers side bright as anything, passengers side dim and weak. weaksauce
Old Jun 2, 2011 | 05:52 PM
LS1121's Avatar
This is what mine look like. They look brighter in person.
Attached Thumbnails Door panel lights-imag0205.jpg   Door panel lights-imag0206.jpg
