Kee Audio Stealth sub box package install (Stock Monsoon Head Unit).
i have a aftermarket headunit in mine and have had mutiple systems hooked up to it so i should just be able to splice this into mine. how long will this be on sale on yoru site kee audio?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I just ordered the same sub box and sub from Kee Audio. I already have that same amp, got it dirt cheap from a friend. I have the same wiring kit too from The Install Bay (haven't opened it yet).
What is this?
![](http://img835.imageshack.us/img835/2122/img8977u.jpg)
And what did you mean when you said you had to use 12gauge wiring instead of the crappy speaker wire for the sub, did you have to buy that separately?
What is this?
The circled thing was a battery terminal adapter to replace the stock terminal on the battery. The adapter has an extra bolt on top of it to attach your power wire making it much easier to get to and a cleaner appearance.
You can attach screws right into the plastic on the stock mount.
That amp is now discontinued from Audiopipe, they make a 2 channel version that is the same size but the monoblock one they had is gone now. I have a new amp I am using that is just as good and more powerful. It also has the adjustments on the side instead of the ends making it easier to tune. The Audiopipe was a great little amp but the adjustments were on the bottom of it because it was so small. Made tuning a bit harder to do.
Still have this set up with the new amp from SSL and I also have discounted the one with the RE Audio sub down to $299.99 so it is a stellar deal to add some serious bass to your F-Body.
