Help guys !
Old Sep 7, 2011 | 08:21 PM
jrplz's Avatar
Unhappy Help guys !
Ok bought and Lt1 camaro 1996 for my daughter want to surprise her also have a soud system I want to put it it but. I cant seem to find a dash kit (for radio) that I could put also an eq and radio 1.5 din kit do any of you have the part number for this kit ? or pics thanks guy
P/S
DID THE GOOGLE SEARCH NO LUCK !
Old Sep 7, 2011 | 08:52 PM
bigj2717's Avatar
Why do you need an eq they are built into almost every aftermarket radio
Old Sep 7, 2011 | 09:09 PM
jrplz's Avatar
Panasonic "Ghost Face" touch screen LCD AM/FM/CD/MP3/WMA with CD
trust me I do need to put this eq/linedriver
4 alpine speakers
2 JL audio w6 old school
1 alpine 4 channel amp
1 old school rockford fosgate 601s
if anyone has a dash kit part number please let me know thanks
Jr
Old Sep 7, 2011 | 09:14 PM
bigj2717's Avatar
You wont find any kits for that you'll have to make it yourself.
Old Sep 7, 2011 | 09:17 PM
jrplz's Avatar
ok thanks if anyone know any tricks in doing this will be greatly apriciated
Old Sep 7, 2011 | 09:45 PM
bad_408_vert's Avatar
cut once measure twice
you can probably get a radio "block off" panel, basically its a big piece of ABS plastic.
Make your own slots.
You 'll also have to find a way to secure the EQ since the 1.5din aftermarket headunit will be secured by the only holes in the stock radio cage.
Old Sep 8, 2011 | 03:46 AM
jrplz's Avatar
thank you I will do that Im ordering some stuff from sonics let you guys know the outcome !
thanks again
Old Sep 8, 2011 | 07:16 AM
WhiteBird00's Avatar
Ungrounded Moderator
Metra makes a "multi" kit for GM models that fits the 1.5 DIN opening and comes with four different face plates to mount a single DIN head unit and a 1/2 DIN equalizer. You might be able to make that work in the Camaro although you may have to fabricate some brackets. The part number is 99-4544.
Old Sep 8, 2011 | 11:06 AM
jrplz's Avatar
thanks
Old Sep 8, 2011 | 11:09 AM
dragonrage's Avatar
You could also put the EQ in the trunk and just set it once, or - better - www.minidsp.com
