Kee's Ultra High End (Kinda!) & MORE: Install
#81
Hey rauch there is a rubber seal that you can use to rout your power wire through on the passenger side of the car. It is down below the ecm. You just take one of them out which isn't hard to do and you don't have to unplug it. then just look and feel down there and you should find it. Then you take the plastic dash panel out that's under the heater core you will pull the wire through but if you go this rout its best to use a friend to help you so you don't damage the power wire trying to pull it through this is how I did mine
