I need help replacing the door speaker, taking off the door panel?
okay guys i got a 1998 ta with monsson, i have a blown driver's door speaker and i am just replacing it with another crappy monsoon speaker. i tried to take the door panel off, i am not sure if i am doing it right. i took off the little triangle peice that goes to the mirror, and the two or three big screws in the door handle. but i can seem to reach the left one, you have to be at a deep angle and i am not sure what the hell i am doing. i am not sure about the wiring harness either. any hel-p would be helpful.
1) Take off the triangle behind the mirror.
2) Roll your window down.
3) Gently pry off your lock/window/mirror switches and disconnect them.
4) Take off the piece where you door lock is (pay attention how the slider comes off, because it is difficult to put back on.
5) Unscrew the 3 large screws under the handle.
6) Push in on the door panel while pulling up. Sometimes it is easier to get the top lip of the panel off first. It only has to come up about 4 inches and the whole panel will come off.
Good luck.
Paul
Good luck.
Paul
