Low Trac Light....?
Old Oct 31, 2011 | 08:27 PM
Stocker94z's Avatar
Default Low Trac Light....?
I have a 99 Camaro 3.8 M5 with ZERO options. No power windows, locks, no rear defroster, I literally mean nothing. Well I noticed when I'm driving in a spirited way and I lose traction for some reason between shifts my Low Trac light comes and I was wondering if it's just a light or will it actually cut power and is tied in with a traction control system?
Old Oct 31, 2011 | 09:13 PM
2001-CamaroSS-LS1's Avatar
it is tied in with the traction system and yes it will cut power...you should feel your gas pedal fight back..like it wont let you push any more...do the 3.8s have ASR or traction control?
Old Nov 1, 2011 | 08:37 AM
cemlsx's Avatar
mine doesnt have traction control , was originally an open rear 3.08 , and I gott eh low-trac light ..
In my case it was just a light , I dont have traction control so nothing would cut power or anything ..
if you dont have traction control on your car , I`m pretty sure yours is also the same ..
Old Nov 1, 2011 | 08:49 AM
wssix99's Avatar
Save the manuals!
Low Trac comes on for traction control or ABS. (They use the same sensors.)
The system activates, when your wheels slip. This causes the wheel speed sensors to sense that your rear wheels are moving faster than your front wheels and that you are skidding.
1) If you are driving so "spirited" that this is happening, you are driving with too much inspiration. The computers will allow some slip but will snap at you when you are really inefficient. (If you really aren't slipping that badly, you could have a wheel sensor issue.)
2) How the hell do you get a 3.8 to spin the tires like that? Are they slicks or bald?
Old Nov 1, 2011 | 08:56 AM
cemlsx's Avatar
^ good point , mine only came up twice , and one was in the rain when the rear wheels spun a bit too much ..
other then that , I`ve spun my rear tires up to 60mph countless times with the LSD and 4.10`s , never got the `low-trac`` light ..
It definately shouldnt light up during shifts right ..
Old Nov 2, 2011 | 01:32 AM
14k's Avatar
14k
mine comes up every now and then i have ABS INOP on and a ses for a speed sensor
Old Nov 2, 2011 | 09:34 AM
wssix99's Avatar
Save the manuals!
Right. You'll be more apt to get a low trac light when the rear wheels are spinning at different speeds.
That gives me an idea for the OP - Do you have different tires right and left? (I wonder if one is getting more traction than the other.)
Old May 10, 2012 | 10:00 PM
Stocker94z's Avatar
Old *** thread I know but I haven't been on in awhile. And if I'm rolling at 20 in first and hit it I spin and get wheel hop pretty bad, you can hear the hatch shaking lol. It's just a bone stock 99 5 speed 3.8. It does a hell of a burnout lol. Just a 3:23 open on pretty fresh 245's.
Old May 11, 2012 | 04:53 AM
cemlsx's Avatar
well you shouldnt be getting any wheel hop , hows your suspension ?
maybe bad shocks or something is causing the wheel hop..
Old May 11, 2012 | 10:35 AM
bad_408_vert's Avatar
I 'd say get it scanned at local parts store with a scanner that can read abs codes to find out exact what is the problem.
I had something similar. Low Trac light used to come on, now abs light was on for sometime. Turned out to be a wheel speed sensor.
If I had to guess the wheel hop , then your rear sways needs some work or replacement.
