- Camaro 1990 to 2002 How to Make LED Turn Signals<br>Step by step instructions for do-it-yourself repairs.
LED turn signal problems
Look in the C5 section under lighting.
They are $45 a pair and a pair of load resistors is $7. And shipping is free.
what i did find on there were a few treads with guys complaining about defaults in the bulbs. now if i go buy the 'Keep it clean' flashers, then will they protect my bulbs from power surges and quick changes in voltage causing the bulb to blow? or do i still need a load equalizer/resistor?
After disabling DRLs, with headlights off, the front lamps will flash amber when using turn signals otherwise they will be off. With headlights on, the front lamps will be on white and will switch to amber flashing when using the turn signals.
Whoever is saying that rapid voltage changes damage LED bulbs doesn't know what they're talking about. I have my LED bulbs connected to a strobe flasher that allows me to run them as strobe lights when I'm working charity events. That's about as fast as the voltage can change and they are four years old without problems. A power surge could possibly be an issue but if your car is experiencing power surges going above about 16 volts (the LED's limit) then you have bigger problems than bulbs.
Thanks for all the info WhiteBird00 i read 4 or 5 lengthy threads u dominated. Lol So u helped me more than you know. Btw... Dont hate me but i bought the red/white flashbacks. Im going to be painting the car silver with black and red retro style birds on hood, sail panels, and tail light panel. Along with a rear window decal. So red/black trim will be all over the place. I think the flashback i got will b a perfect match.
I'm looking for a digital flasher so I can run my LED setup for my DRLs.
The one I ordered has 4 prongs and when I pulled the original, it only has two.
It's for a 2000 WS6.
Does anyone know which pn is needed for this.
keepitcleanwiring(DOT)com/catalog/Relays%20and%20Flashers/Flashers/FF552NLF
I would rather see them flash amber than white, but you can get them that flash;
Amber - Off - Amber - Off - Amber - Off
- or -
Amber - White - Amber - White - Amber - White
I would rather have amber - off, but to get the DRL colors I want switching the bright/dim will create white flashing turn, which I don't want. But if I get the a-w-a-w flashing I will still get amber in the turn, right?
- or -
Unfortunately, f-bodies use the bright filament power for both DRLs and turn signals. The dim filament is used only for parking lights when the headlights are on. So you can choose white or amber for either one by swapping the wires but you can't have DRLs a different color from turn signals without significant rewiring.
First you would have to disable DRLs at the DRL module or bypass the DRL module for turn signals only. Then you would have to rewire the parking lights to work like DRLs.
- or -
white flashes off and on and the Amber stays on(appears W-A). When the headlights are on the LEDs are amber and flash amber-white.
Even the wifey was impressed and liked it.
Now here's some irony..
When I checked em and saw everything was good, I turned on my fogs to see how they would look and one of them is out....LOL
Soooo I picked up a pair of Silverstar bulbs to replace em.
I will change those on Thursday as it is not a quick swap out.
Looks like I need to remove the air dam to get access.
