- Camaro 1990 to 2002 How to Make LED Turn Signals<br>Step by step instructions for do-it-yourself repairs.
LED turn signal problems
they are the 3157 type which is same as stock. well.... i put them in and they worked great! i didnt notice til the next day that they only work as the parking light. and will not flash.
i tested my system, and stock bulbs still operate flawlessly. i noticed my reverse lights are the same size/style (not code) and they DO the same thing as the LED's (dont flash) its because they have one light source im assuming? (LED's&Reverse Lights) and the stock DRL's have two. you can see the double wire set up in the bulb.
so my question, where do i find pain-jain ultra white led bulbs that will function correctly, for not friggin' $30 a bulb.
also, in not against flashbacks. i actually want them.. but havent found a decent priced set.
i must have read your all's mind.
lolhave long have you used them with out the EL12's? i think im going to go ahead and get the EL12's bc ill be putting in a sequential tail light kit soon. BTW.... will i run into any problems there? switch back front turns and sequential tails (ill probably use stock bulbs due to melting issues i've read of) with both the flasher modules being EL12's.
http://www.ebay.com/itm/White-Red-Sw...item588829af49
First, red lights are illegal on the front of any vehicle except emergency vehicles - and believe me, it's not something the police take lightly.
Second, even if you got amber/white switchbacks, the only time they would be white is when the headlights are on - the DRLs, parking lights (without headlights) and turn signals would still be amber (BTW, white turn signals are also illegal front and back).
Third, you need either an electronic flasher or a load equalizer to make the turn signals work properly with LED bulbs. Anybody who tells you differently just doesn't realize they already have one of them installed. And the turn signal and hazard flashers are the same - just standard 2-prong flashers.
Finally, I don't even want to get started on how dumb and dangerous it is to install an HID kit in halogen reflector headlight housings. Especially those silly blue 10K ones. And HID foglights? Madness.
Look in the C5 section of the JW Motoring website and look under lighting.
They are $45 a pair and a pair of load resistors is $7. And shipping is free.
When I installed my Switchbacks from
Autolumination the Amber lights were on bright circuit when the DRLs were suppose to be on and flashed
amber-off. The amber and White lights were on when the parking lights were suppose to be on but appear to be Amber and it flashed amber-off and the white stayed on. When the headlights were on the white light were on and flashed white-amber.
I switched the blue and brown wires in the
socket. Now the white lights are on the bright circuit for the DRLs and flash white-off . The parking lights appear
white but both Amber and White are on and the
white flashes off and on and the Amber stays on. I
have all factory wiring and I've only switched
two wires in each socket. . When the headlights are
on the LEDs are amber and flash amber-white.
I live in NC and the law here specifies white or amber for the front turn signal.
flasher. I bought them when I originally got my switchbacks and I had times when either my turn signals or flashers wouldn't work. So I went ahead and got an electronic no load flasher from Keep It Clean.
Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
Look at G.S.20-125.1. Directional signals.
(a) It shall be unlawful for the owner of any motor vehicle of a changed model or series designation indicating that it was manufactured or assembled after July 1, 1953, to register such vehicle or cause it to be registered in this State, or to obtain, or cause to be obtained in this State registration plates therefor, unless such vehicle is equipped with a mechanical or electrical signal device by which the operator of the vehicle may indicate to the operator of another vehicle, approaching from either the front or rear and within a distance of 200 feet, his intention to turn from a direct line. Such signal device must be of a type approved by the Commissioner of Motor Vehicles.
Also look at:
http://ncrules.state.nc.us/ncac.asp?...tor%20Vehicles
19A NCAC 03D .0537 DIRECTIONAL SIGNALS
(a) G.S. 20-125.1 requires all vehicles except motorcycles beginning with the 1954 models to be equipped with turn signals.
(b) Vehicles required to have signals shall be inspected and disapproved if:
(1) Signals are not present and of a type approved by the Commissioner as specified in G.S. 20-125.1. Original directional signals on vehicles manufactured after July 1, 1953, are considered to be of a type approved by the Commissioner. Such signals shall be those which will allow the operator of the vehicle to clearly show another operator approaching from a distance of 200 feet from the front or rear his intention to turn the vehicle.
(2) All lights do not operate properly, or if any lenses are broken, missing, or do not fit properly.
(3) Signal lens color is other than red or amber on the rear and other than white or amber on the front.
(4) Lamps are not securely mounted or wiring and connections are not in good condition.
(5) Signals are not visible from front or back due to faulty or damaged mounting or due to manner in which mounted.
(6) Switch is not so located as to be convenient for the driver to operate and so that its operation does not interfere with operation of other mechanisms.
My disagreement is with the statement concerning the DRL/Parking Lights and Turn Signals.
North Carolina General Statutes § 20-134 Lights on parked vehicles
(a) Whenever a vehicle is parked or stopped upon a highway, whether attended or unattended during the times mentioned in G.S. 20‑129, there shall be displayed upon such vehicle one or more lamps projecting a white or amber light visible under normal atmospheric conditions from a distance of 500 feet to the front of such vehicle...
Here's a link to the NC Safety Inspection Enforcement rules:
http://www.ncdot.org/download/dmv/CR...nforcement.pdf
19A NCAC 03D .0533 LIGHTS
5. Parking lights shall conform to the requirements of G.S. 20-134. A
vehicle shall not be approved if parking lights are not working. Parking
lights front, white or amber, rear, red only.
my dad is a cop.... and i know every officer in the county that i live in. got it on lock down. haha
and ill do alot of adjusting trying to keep the glare to a minimum. sorry guys if i pass you. i mayve went a little overboard with it... got excited. by bad. lol and the info on the flasher problem is much appreciated. i could not find that anywhere. Look in the C5 section under lighting.
