cut yellow wire going to radio..
I have a 2001 trans am WS6 that is having issue's with the radio cutting out & the windows don't work. This is a pain ..can't figure out what is wrong with this. Bought the car brand new nothing has been messed with in the radio..can someone help
Ungrounded Moderator
Somehow you are getting constant (battery) power on a wire that should have retained accessory power (RAP). The RAP circuit is controlled by the BCM so your first step is to find out if the BCM is producing constant power on the RAP output wire. If it is then the BCM is the problem. If it isn't then somebody has messed with the wiring to the radio.
No, that was my response and you were told that the BCM fix discussed in that thread wasn't related to your problem. Nobody said it wasn't a BCM problem just that it wasn't that particular BCM problem. Quite the opposite... the thread discusses fixing radio and windows cutting out intermittently whereas your radio won't shut off.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
ill get back to you on the BCM later in the week.
