Old May 10, 2016, 02:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
Print Wikipost
drivers side window, switch problem.
Old Feb 15, 2012 | 03:44 PM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by wssix99
VIP1 - have you tried the Dorman motors yet?
No its a Seimans. I bought it a few years ago before the Dorman motors were known.
Old Feb 15, 2012 | 10:38 PM
wssix99's Avatar
Save the manuals!
After messing with the Siemens motors, I went to an aftermarket motor/regulator combo, which ended up being worse. I've just gone to the Dormans and after one year, they are still going strong just like the car did when it was new from the factory. Hopefully they will hold up.
Old Feb 21, 2012 | 06:52 PM
crw3673's Avatar
There are so many issues with these things that buying them from a local store with a lifetime warranty really pays off.
you were exactly correct! Took the ebay window motor apart, to do the resistor mode. To find the armature, totally cooked! The winds on the motor, came apart and completely frozed the motor. Then started melting the end cap. Was better off buying from local auto part store, with warranty. Next will try using the guts and end cap, from old motor. With case and magnets, from ebay motor.
Old Feb 21, 2012 | 07:49 PM
VIP1's Avatar
Which armature was bent?
Old Feb 22, 2012 | 04:50 AM
crw3673's Avatar
nothing was bent. The wires that wrap around the shaft, of the electric motor. Were not wound, tight enough. So when the motor was turning, it eventually jammed the motor frozen and pressing the button to go up and down, on a frozen motor, just cooked the plastic parts inside!
Old Feb 22, 2012 | 12:08 PM
VIP1's Avatar
Oh, I misread "cooked" as "crooked".
