- Camaro and Firebird Why Are Power Window Not Working<br>Guide to diagnose trouble and recommended solutions.
drivers side window, switch problem.
It's not doing the usually go up, slow down, and stop...wait a few mins and works again... it's doing it on the way down and up...and returns a few secs after with full power...and will function perfectly.
I suspect the switch might be bad? passenger is fine, also new... dorman..
I hear a click underneath the steering column when im pressing the switch to go up or down, no idea what that could be...
Also, is their adjustment im not aware of? I'm having a problem with my door not closing since the motor was put it, the window hits the t-top right before it's going to close, and it's super hard to get it to shut, you gotta slam it, i tried like every adjustment i dont get it... u can see the t-tops move when u shut the door..sometimes the window won't go up all the way, its almost like its hitting the weatherstrip wrong.
Thanks everyone..
Don't worry about the clicking. That's just the express-down module. If you press the button, hear the click, and the window does not move - that means your button is fine.
I have a new switch ordered.
I still can't figure out this window alignment stuff, the window hits the weatherstrip too quickly so the door has to be slammed to close, I tried every adjustment I could think of.
Oddly enough, If i roll it all the way up, but roll it down just a bit, it'll close perfectly, it seems when it gets all the way up the window will push in towards the car, there was an adjustment I was playing with that stops the window from going up to far, but it didn't really do anything, I also noticed, the window guide towards the rear of the door, when the window is turned all the way up, it'll actually move the bolted down guide up some, because the piece that's attached to the window with a star bolt reaches it too quickly I guess.
It's annoying and hard to explain I just want to be able to close the door right, Ive played with the adjustments 3 times now, for hours sometimes.
I think this issue is related to my regulator spring coming off inside the door, it's been like this since I bought the car, i had a new regulator and motor put in, and the door still closes the same, seems like a mess up from the factory?
Here's the window alignment guide: http://shbox.com/1/adj_window.html Just make sure you do the adjustments in the order listed or you will be out of whack.
While you are back in there, get some SylGlyde from Napa. (That's the only place I can find it.) Its the exact match for your track grease and should be used liberally to lubricate your tracks and regulator. It will also help your issue.
A missing door regulator spring will make it harder for the motor to put the glass up and will cause the motor to burn out faster and have more issues like this. I assume your new regulator has a spring, though? If so, you could have a bent track or some other obstruction in the system. I'd try a good alignment first.
Who did your regulator install? Were the proper GM rivets used?
Thanks for the tips.
You should take the motor back and go for the Dorman model, which is 100% new parts and an updated design.
Seems the two left rivets are moving some, and some of the fiberglass is chipping off the outside, are they supposed to move at all? Maybe I'm just being ****, the chipped outside could've been from the removal of the old assembly, they move alittle when the window goes full down, it does seem the hole is bigger then the rivet..but still...
I did fix my alignment issues, now this I have to worry about! its never ending
Its normal for those holes to get bigger the more that a regulator is removed/replaced, but you won't want those rivets moving. If they move, they could slowly tear those holes larger. If you do have movement, you may want to proactively put in a backing plate.
That being said, its not going to be an issue of tightness. The holes for the rivets are probably just too big. You might infer that they drilled them out too big. They could fix the composite or add a reinforcing plate.
I think I'm going to bypass the thermal breaker in the motor and also bypass the auto-down using relays and thicker wire to get more voltage and current to the motor.
I wonder if something like the Catz Zeta system would help here? Its a booster/ballast intended for Halogen Headlights. It takes the cars 12v-14v input voltage and outputs 15V+. I've never seen anyone use it for a window motor so I don't know if it will work or cause a fire.
and wssix99, I will furnish this information to the shop when the weather gets better and I bring it there, I as well presume the holes were drilled too big, also, I noticed on some rivets, the center is deeper, and others is almost flush with the jacket/hat.
