need help with turn signals
I really don't like chasing wires! - Try your turn signals and brakes at the same time.
- Try your turn signals and parking lights at the same time.
- Try your turn signals and headlights at the same time.
- Try your turn signals and high beams at the same time.
Do any of those cause your fuse to blow?
You might try doing a search. I have a manual but faintly recall seeing something like this (reverse switch) before...
In order to have a short between the reverse circuit and turn signals, they would need to cross somewhere. The only place I can think of where that happens is in the wiring harness going to the back of the car.
One easy thing you might also try is unplugging the rear lighting harness. That plug is just inside the rear wall of the car, behind the carpet that lines the rear compartment. If you put the car in reverse with it unplugged, that should help you isolate if the problem is inside the car or at the rear harness.
With your comments above, I'll bet Dr. Frankenstein owned the car before you and did some "work" on that rear harness...
