Opinion on Amp/Speakers
1st: should I run the new speakers off the factory amp or of the HU ??? I know this depends on the speakers I use in the setup, I was thinking about a keeaudio standard camaro kit, but I was at fry's and saw that they had some infinity kappa that are 2ohm.
I just want to get the best bang for the buck but still keep my system simple, I do want to add a subwoofer down the line(I'm replacing my carpet and adding sound deadening product, so I 'll be running the necessary cables).
what should I do ???
Keez bazooka 6.5" dvc subs for the back sail panel sound amazing. Some nice component 6.5" front pioneer or Alpine speakers would help out also. You can run high power inputs to an amp from the HU, But Why keep that head unit. The signal it is putting out is not nearly as clean as one you can achieve with an aftermarket HU.
6LE sells double din bezels for the radio. A nice 6.5+" touchscreen shouldnt run you more than $500. This would add MP3 ability plus the sound will be mountains above what your used to. Plus You can run RCA cables to the amp from these head units without HI/LO adapters as would be needed if your amp doesn't have that feature built in.
Or just run new speakers off these units and save the amp for a sub or two in the trunk. I would run better wires to the speakers locations if you went either route.
Good luck!
you didnt say if you had the monsoon or not, but with you bringing up factory amp im guessing you do.
if you go with kee i would go with the upgraded standard package. it would be the best bang for buck. the standard package would save a few bucks, but the upgraded standard would sound better with the monsoon.
the infinity wouldnt sound bad, but would probably come out more expensive and it sounds like price is something you want to keep as low as possible
, which led me to think that the monsoon amp wasnt working i hooked up the speakers to it and it works just fine, i cant tell about sound quality because previous owner replace stock speakers with some cheep offbrand stuff. I want to keep everything as simple as possible which is why if possible want to use the stock amp.Ive been reading the stickies and it seems like you have to do some mods on the door speakers (4 cables). Also the sound coming to pilar speakers are all low frequencies and hatch speakers are all highs.
Mid-bass subs in a camaro are SVC, not DVC. Don't get the Bazookas with the stock amp.
Just get component speakers for the doors, they will sound better and require all 4 wires, no mods required. You just have to get some "convertible" or coaxially mounted tweeters for the Camaro. Two-way speakers will also work but generally they won't sound as good and you'd be giving up some of your power from the Monsoon.
next to the rear seats do only get lows though, because they are small subs. you do have options though. you can go with the kee audio package that has the subs. since you want to run a sub you can also run those off the headunit instead of the monsoon. you would lose a little power to them, but they would get full range.
This wat all speakers are on the monsoon amp and i can just get a mini amp for a small 10 inch to get the base ???
Are there connectors for the front speakers or do i have to splice into the wires??
Now the front speakers two wires go to the amp and other two to the hu.
