blowing blinker bulb
Old Apr 21, 2012 | 11:39 PM
rgarner~z28's Avatar
Default blowing blinker bulb
i just bought a 2000 z28 i have put two blinker bulbs in it and have blowed both in about a month and where the bulb goes in is a lil burnt got ant ideas?
Old Apr 22, 2012 | 03:24 AM
JrodCamaro's Avatar
New socket
Use dialectric grease with new bulbs also
Last edited by WhiteBird00; Apr 23, 2012 at 08:10 AM. Reason: Merge consecutive posts
Old Apr 22, 2012 | 12:44 PM
Originally Posted by JrodCamaro
New socket
where do i find new socket?
Old Apr 22, 2012 | 12:47 PM
JUSTINSWS6's Avatar
Pull your stock one go to orilleys or autozone thats where i got mine like 7 bucks
Old Apr 22, 2012 | 12:53 PM
chaman's Avatar
What blinker fluid your running? J/K!
Old Apr 22, 2012 | 03:47 PM
dose it have a place to unplug the socket from?
Old Apr 22, 2012 | 03:48 PM
when its warm like this i run 10w 30 lol
Old Apr 22, 2012 | 05:02 PM
SparkyJJO's Avatar
Get the standard GM socket from Autozone/Advance Auto/where ever. Don't have the guys behind the counter look it up as their dumb computer system will say it doesn't fit these cars. Their computer is wrong, the sockets are a direct fit. Just go to the electrical aisle at the store and the sockets should be there.
There is a way to replace the socket without chopping wires. Here's a socket rebuild writeup I did on another site that should be helpful.
http://www.fullthrottlev6.com/forums...-a-single-wire
Also check for any apparent water damage in the housing. If water drips on the bulb when it is hot, it can crack/shatter the glass and burn the bulb.
Old Apr 22, 2012 | 08:08 PM
thanks that helps alot
Old Apr 22, 2012 | 09:33 PM
wssix99's Avatar
Save the manuals!
Before you do a new socket, check the lens first. The crack, let water in, and that blows the bulbs. Your socket could be perfectly fine.
If you have water in there, the lens will look like a fishbowl and you can press on the lens with your finger to expose the cracks.
Old Apr 22, 2012 | 09:39 PM
JUSTINSWS6's Avatar
Yes these drl lens crack very easy in these cars. I bought new ones and in less than a 1000 miles one has a hair line crack someone must have picked up a rock
Old Apr 22, 2012 | 10:04 PM
SparkyJJO's Avatar
Camaros don't usually have as many cracked lenses. Not sure why
Old Apr 23, 2012 | 08:32 AM
wssix99's Avatar
Save the manuals!
Its because Firebirds go faster and the rocks and road debris hit the lenses harder.
Old Apr 29, 2012 | 07:16 PM
Monzsta's Avatar
I'm going through bulbs at a record rate. Wasn't there someone who had good luck with the ultra bright LED tower bulbs?
Old Apr 29, 2012 | 09:03 PM
wssix99's Avatar
Save the manuals!
Old Apr 30, 2012 | 05:22 AM
Monzsta's Avatar
Originally Posted by wssix99
Hey, he's blowing bulbs. I'm blowing bulbs. Completely relevant to the topic. There was no mention of possibly upgrading to something sturdier that may help him and myself out so I made it.
Old Apr 30, 2012 | 08:46 AM
YellowTA1's Avatar
change out your housings, that way there are no cracks in the top from the filament bulbs, get new sockets if your old ones are corroded, replace bulbs with LED tower bulbs (i used the 3157 amber drl) problem solved...
Old Apr 30, 2012 | 10:26 AM
wssix99's Avatar
Save the manuals!
The thread is all about lens problems. A new bulb won't fix the lens.
Old Apr 30, 2012 | 11:04 AM
Monzsta's Avatar
Thanks! That was most helpful. I'm going to look into that. I'm also going to look into supporting the lamp housing a little better as they aren't really firmly attached to anything solid, and I think vibration is also playing a role in the short bulb life span.
Old Apr 30, 2012 | 11:18 AM
YellowTA1's Avatar
I am not sure about that, I've had my LEDs in for over a year, and have had zero issues, what causes the short span is the design, the bulbs are bottom-mounted, and get so hot they melt and crack the top of the housing, letting water in when it rains/washing, ruining the socket, I think changing housings/sockets/bulbs to LEDs you will be fine. The pic in my sig is how they light up after the change, for reference.
