Sail panel subs.
Old Jun 29, 2012 | 07:14 PM
bajaboy501's Avatar
Default Sail panel subs.
Well I got rid of my stock sail panel subs. I replaced them with Audiopipe TS-AR6. The specs are 150 peak and 75 rms. Magnet is a decent size on them. I havent found any reviews on them and I currently havent listened to them yet. I will update on how they sounds when I give them a week or two to listen to them. I took some pictures for you guys if you wanted to have a look. I may not keep these for very long, but I got a decent deal on them. I will be saving up to either buy the Bazooka speakers or the CDT speakers. Enjoy and give me some feedback. Thanks.
Old Jul 2, 2012 | 07:34 AM
WhiteBird00's Avatar
Ungrounded Moderator
I had those in my sail panels and the sound was quite good - a significant improvement over stock. However, Ian (Kee Audio) reports that he has had some problems with failures in them so he doesn't recommend them anymore. Mine lasted a couple of years without problems and were working fine when I sold the car.
Old Jul 2, 2012 | 09:15 AM
moperider's Avatar
I have the CDT'S and the driver side sounds like it has blown coils. Have had them less than a year. The full range CDT's in the hatch were also cracking but the cables going to the tweeter were hitting the speaker so I just bent them back and that fixed it....however that's just poor craftsmanship.
Old Jul 5, 2012 | 04:54 PM
JOSH13's Avatar
I have these in my sail panels and I think they sound pretty good. In my car I did have to take them out a few times and put in some dynamat .... Other than the rattling I think they sound good. I think after I got a 10in sub in the back I appreciated them more for the mid bass they provide if that makes sense ..
Old Jul 6, 2012 | 12:22 AM
00'TwistedLS1's Avatar
Not exactly a professional at this stuff but Wat kind of amp are u going to use for these if any?
Old Jul 11, 2012 | 11:58 AM
LS1SSZ28's Avatar
I have kickers that are 150rms
I used a kicker 300.2 to power my 2 6.5 2 ohm subs, and with my new headunit it SOUNDS AMAZING!
Old Jul 16, 2012 | 08:43 AM
bajaboy501's Avatar
Twisted I am not using any amp with them, they run off of the factory monsoon amp. I am kind of impressed with these speaker, although they dont seem to have as low of a bass note as the stock speakers if that makes sense? Maybe because they dont have enough air space? If anyone wants to chime in I would be glad to try things. They sound much better than that factory fart noise coming from a blown speaker!
Old Jul 16, 2012 | 08:50 AM
LS1SSZ28's Avatar
I thought the same thing regarding the low notes, but i was also getting alot of rattle. So i went back and installed mdf spacers which did give them a little more room to breath.. and that made them sounds better.
Old Jul 16, 2012 | 11:39 PM
White6SpdZ28's Avatar
I bought the bazookas they are better than stock.
Old Jul 17, 2012 | 09:02 AM
bajaboy501's Avatar
I may try the bazookas at a later date, im not really sure that these will make that much of a difference since I am going to put a full system in the car anyways. What size spacer did you use LS1SSZ28?
Old Jul 18, 2012 | 05:26 PM
mjs1012's Avatar
To the guys who have aftermarket "subs" in the sails did you run an amp bridged to them or just run them off the stock stuff?
