C6 Android Tablet Stereo In-Dash Install
If it did, you could possibly run a different (lower voltage) kernel and have it run a little cooler, although that wouldn't really keep the tablet from getting hot while its not running
http://cdn.thenextweb.com/apple/file...x2_1036c7a.jpg
What volume app is that you found? I found an App called "Auto Screen On" that will let you wave your hand in front of the proximity sensor to wake the screen, as a way to get around needing to use the physical buttons.
-Dave
So when you turn the car on this app turns the screen on? Do you then have to unlock it? I suppose you can change the settings not to lock. Do you have the settings so it doesn't turn the screen back off?
