Stock Cooling Fans
I've seen the wiring diagram in my service manual and it is somewhat ingenious. you might be able to google it and find the diagram online.
fyi if any of the relays fail then you will not get full operation of your fans, depending on which relay fails. having 3 relays is not for safety, and any one relay can power both fans. they are rated well above what the fan motors draw. having 3 just lets you control the fans like i mentioned, with common electronic parts.
this thread post #36 has the fan wiring diagram, "First heres the diagram to wire up the camaro dual fans. This diagram is for the fans to be dual speed."
at the pcm there's dk gn wire pin 42, when just that is grounded fans run in series electrically and at low speed. When both pin 42 and pin 33 dk blu wire are grounded relays make the fans run in parallel at high speed.
also, not all 3 relays are the same. The 2 relays on the outside of the diagram are a simple on/off relay (SPST - single pole single throw). the center relay is a SPDT (single pole double throw) relay.
I found a wiring diagram and was alittle confused at first. Finally figured out that they do run in series and then in parallel.
Also played with the PCM wires, and saw what each wire does. I'm rewiring my car.
It's a track only car. I'm going to put in a aux switch, to turn the fans on manually.
Still let the PCM turn them on, but manually turn then on in the pits in between rounds.
Again thanks!
Which fans do I need to manually turn on in the pits and staging lanes to keep car cooler.
Both fans on low, both fans on high or single fan on high?
93 TA M6, CC stage 3 clutch, freshly built trans, AC delete, CAI
The electric fans are controlled by the PCM. one relay is grounded by the pcm for low speed, or two relays get grounded for high speed. When the AC is turned on, the PCM knows high refrigerant pressure via a sensor and when it's over so many kPa it turns the fans on low speed or high speed just like it does with coolant. I know whenever you drop below 30mph too with the AC or defog on the PCM commands the fans on.
for staging you'd want to ground both wires to make both fans on high speed.
with the fans on high speed you will know when you turn the car off so it's very hard to not notice and forget. Leaving them on low speed is a different story. I've manually switched mine on low speed then forget when I got to work. Low speed fans ran from 9am to 4pm. Car started, but obviously don't take that as a guarantee you can leave your fans on low speed for 8 hrs and not have a problem. If you're battery is decent, low speed engine off for 1-2 hours should not hurt the battery.
if you're electric fans to never seem to turn on while you are diagnosing, it may be because you're coolant temp is not hot enough. I'm pretty sure however they will always turn on low speed when the AC is turned on and you are parked. You should do that then probe the 2 radiator fan wires from the PCM to the relays and make sure just the one which does low speed has continuity to ground. Check the link above for the pin # and wire color for the low speed, I don't remember.
I bought a DPDT switch, put the fan relay controls on the common terminals, the PCM wires on one side and a grounded wire(s) on the other side. That way I can leave the switch in the down position and let the PCM control them and override them in the top position. Also wired a indicator light to the fan wire after the relay, so I can tell when the fans are on.
Thanks everyone for the info.
