Headlight not staying up
Old Dec 22, 2012 | 05:30 PM
mopar02's Avatar
Default Headlight not staying up
I have a 97 TA. The left headlight just recently started going down when the lights were turned on. It comes up but then goes back down. The right headlight is fine. Thanks in advance. David
Old Dec 24, 2012 | 11:13 AM
VIP1's Avatar
Copy & Paste Moderator
Does it fall down like something is loose or does the lift motor pull it back down?
Old Dec 24, 2012 | 07:26 PM
Blackpanther99's Avatar
Could be the motor having problems or the wiring. Check on the Firebird forums on the stickies, you should find good info with your problem
Old Dec 30, 2012 | 06:15 PM
mopar02's Avatar
Motor is pulling the light back down.
Old Dec 30, 2012 | 08:42 PM
VIP1's Avatar
Any odd/extra noises?
Old Dec 31, 2012 | 08:34 AM
wssix99's Avatar
Save the manuals!
Got an idea.... Assuming that the linkage is in the correct place and solid.
I wonder if a previous owner did the 180* switch on the gear and that a bad tooth at the top of the gear is causing it to be limp? If so, the gear would catch again going down with the weight of the door acting on the good teeth?
Old Dec 31, 2012 | 05:43 PM
mopar02's Avatar
No extra noises and it has the metal gear installed.
Old Dec 31, 2012 | 05:58 PM
wssix99's Avatar
Save the manuals!
That doesn't mean that its better. They strip too. Mine actually stripped faster than the plastic ones!
