Installing a hu with no internal amp to stock monsoon amp
Hi, i want to know if it is possible and if it is how to install a head unit with no internal amp to the stock monsoon amp.
Thanks
Thanks
Ungrounded Moderator
I have never seen an aftermarket head unit with no internal amp. The factory Bose in 93-96 Camaros had pre-amp output only but every aftermarket HU I've seen has had speaker level output.
I suppose there might be some high-end equipment that is designed only for use with an external amp but (as pentavolvo said) it won't work with Monsoon because the Monsoon amp requires speaker-level input. Besides, if one was buying a high-end component like that, why use a low-end amp like the Monsoon?
