Another blinker problem
The passenger side works perfectly fine both front and back
I replaced the front drivers side signal bulb and it didnt change anything.
However, when i turn on the hazards, everything works fine except for the drivers side front bulb which wont turn on at all. But both rears work fine.
Also, when i turn on my headlights, all 4 lights come on including the drivers side signal.
Cops stop you for every reason where i live, so any help would be appreciated.
cliff notes: (brand new front signal bulb)
1-front drivers side signal wont turn on when signaling
2-rear drivers side signal stays lit when signaling
3-rear drivers side signal works fine when hazards on
4-front drivers side signal turns on with headlights on
The front drivers side turn signal was pretty burnt. Heres a pic of the bulb... you can imagine how the housing was.
I was palnning on replacing it, but as mentioned before, the light works when i turn the headlights on.
Any ideas?
Last edited by WhiteBird00; Jan 1, 2013 at 09:09 AM. Reason: Merge consecutive posts
It is obvious from the condition of the base of the bulb that you have serious corrosion in the socket which is probably causing the failure. You can try cleaning the socket but you may just have to replace it. Our cars are known for getting water in the front lamp housings causing corrosion.
Do you have water in the bottom of the lens?
BTW - If your socket can't be saved, you can purchase a new socket insert so you won't have to splice in a new one.
Do you have a part number of the piece you're talking about. I couldn't find it online
Thanks
You don't want to splice a new socket. Check out this thread on the best method for repair and the links in the thread for others that contain the part numbers:
https://ls1tech.com/forums/general-m...-up-water.html
The crack is the source of the problem, so the lens should also be replaced. If its in a place where water will escape, that's better than getting a fishbowl effect, but any water getting in there will corrode the socket like you are seeing and can also burn out the bulb. (When cold water splashes on a hot bulb, it can burn out the filament or explode the bulb.)
When I had this issue, I got some Amber lens repair tape to put over the crack while I waited for my new lens and it worked pretty well.
http://www.ws6project.com/user_stor/...l-bulb-socket/
And
http://www.ws6project.com/user_stor/...se-housing-lh/
There's no picture of the second one, but does anyone know if it'll just bolt on? Or will I need to modify it to fit?
However, $54 is a lot to pay just to get the GM pigtail when aftermarket ones that are just as good are available for under $15.
Im still planning on buying them just in case it goes out later on which im sure it will. However autozone didnt have them, they only had universal ones and they were under 10 bucks.
The guy told me they should have them at the dealership and told me how to get a hook up on them.
He was also into muscle carsIll see for how much i can get them at the dealership later on.
And the "new" socket looks just as bad. My current turn signal housings are cracked, but i honestly thought they would last longer. Anyway, im gonna buy new housings to go along with new sockets and bulbs.
My new question is should i buy anything else to avoid my new housing lenses to crack? I heard that the housings get really hot, and that tends to crack the lens. Or, should i just drill escape holes on my current housings to avoid the sockets from corroding?
I hardly get rain, but i do wash my car every weekend.
thanks for the help so far
When changing to LED bulbs, you will have to add load resistors or change to an electronic flasher to avoid the "bulb out" non-flashing turn signals. Also, be careful about the LED bulbs you buy because many are not suitable for DRL use - especially the ones from V-LEDs who specifically disclaim warranty on bulbs used for DRLs. Have a look at superbrightleds.com or autolumination.com.
With a 15 year old car, you will be amazed at how much clearer and brighter new housings will make your lights look.
And will the oem housing be sufficient, or is there a better option? I looked at ws6store, rock auto, gmpartsdirect and they all seem to be oem.
