Good sound deadener?
For the people who used SecondSkin, do you just use the "sound deadener" (the dynamat type stickon bytheral stuff) or do you also use the foam/MLV stuff as well?
edit: I just looked at the Overkill. It looks like it's basically a rubber infused closed cell foam (so a quasi foam/MLV hybrid?) so it has mass added to it (rather than just regular foam).
And yes, ccf is mostly good for decoupling surfaces from rattling against each other from wut I've found
