Buying headunit. Update!!!!
Old Nov 8, 2013 | 08:43 AM
  #41
WhiteBird00's Avatar
Ungrounded Moderator
Red ones. They handle 18-22 gauge wire.
Old Nov 8, 2013 | 08:47 AM
  #42
BoricuaHec01's Avatar
Formally Simplɘ Jack
Awesome deal, I'm assuming that goes for the butt connectors as well. Can't wait, should be fun.
Old Nov 8, 2013 | 08:49 AM
  #43
Yes, all insulated connectors use the same color coding. Red for 18 to 22 gauge, blue for 14 to 16 gauge and yellow for 10 to 12 gauge.
Old Nov 8, 2013 | 09:00 AM
  #44
Gotcha, thanks dude.
Old Nov 10, 2013 | 12:02 AM
  #45
So everything came in except for the steering wheel interface, that should come on Tuesday. I decided to start the install to make sure everything works. Well everything went ok for being my first time installing a HU except that it wouldn't fit all the way cause of the bracket in the back so I had to use the extension of the dash kit that makes it look ugly.
My connector work....
How it stands...
Old Nov 10, 2013 | 10:12 AM
  #46
I'm going to Best Buy right now to get the Metra 99-3300 kit.
Old Nov 10, 2013 | 01:35 PM
  #47
DamonZ28's Avatar
I see you got the electrical pliers.
Old Nov 10, 2013 | 02:39 PM
  #48
Naw I ended up buying the 4 in 1 crimp tool from Radio Shack, def made the job a lot easier
Old Nov 10, 2013 | 02:41 PM
  #49
DamonZ28's Avatar
Yeah, that's what I meant. (whatever they're called!)
Old Nov 10, 2013 | 02:43 PM
  #50
Go ahead and cut (or bend out of the way) the factory rear support bracket. Almost every aftermarket head unit is deeper than the factory one so that bracket gets in the way. You'll never need it unless you plan to put the OEM head unit back at some point.
Old Nov 10, 2013 | 02:47 PM
  #51
If you haven't done this already, I suggest going to Crutchfield's website, adding your head unit to the shopping cart, and it'll suggest the dash install kit to use. I think Sonic Electronix website will do the same.
I installed my new door speakers this weekend too, I'll upload some pics. Took me over 6 hours! (I'm putzy)
Avoid Sonic whenever possible - they deal in "grey market" product (items they are unauthorized to sell) and most products purchased there come without manufacturer's warranty. In fact, several major manufacturers have specifically mentioned on their websites that products purchased at Sonic Electronix are without warranty. You might save a few dollars up front but you'll regret it when you have to spend the same again to replace an item if it fails.
Old Nov 10, 2013 | 02:51 PM
  #52
So I ended up buying the Metra 99-3300 from Best Buy and it was still about 1/2 inch short so I just grabbed pliers and ripped that annoying bracket off, mission accomplished and perfect flush ......
Old Nov 10, 2013 | 03:11 PM
  #53
DamonZ28's Avatar
Very nice, looks good!
Old Nov 10, 2013 | 03:28 PM
  #54
M4N14C's Avatar
Nice finish! You should defiantly hear a noticeable difference in audio quality. Your speakers still stock?
Old Nov 10, 2013 | 03:40 PM
  #55
Ya stock speakers, audio does sound a lot better, great quality like always from Alpine. Next project will be sub/amp, debating if I should upgrade speakers too or keep stock.
Old Nov 10, 2013 | 04:29 PM
  #56
M4N14C's Avatar
If you do it, I suggest getting all your stuff done at the same time. Right now I'm in the middle of installing sound deadener in my car and this has gotta be the 4th time I'm tearing out the interior (1st to clean, 2nd to upgrade speakers, 3rd to wire sub/amp, 4th to install sound deadener).
Hope it will be my last for a while
Old Nov 10, 2013 | 05:10 PM
  #57
Sound deadening might be a bit much for me but if I went with sounds, I'll prolly just upgrade the front speakers, get a 10" Type R with mono amp and possibly 4 channel amp for speakers.
Old Nov 12, 2013 | 05:43 PM
  #58
Steering wheel interface came in today, just installed it, good as new.
Old Nov 12, 2013 | 06:43 PM
  #59
M4N14C's Avatar
*envious*
I'm a bit OCD when it comes to my car as I want everything to work perfectly. Useless steering wheel buttons are slowly driving me crazy
Old Nov 12, 2013 | 07:07 PM
  #60
*envious*
Ya man same with me. Last couple days was driving me nuts trying to push the volume/mute buttons out of habit and knowing they didn't work made me and the car incomplete. Were you able to get yours resolved?
