Buying headunit. Update!!!!
Old Nov 6, 2013 | 08:46 AM
BoricuaHec01's Avatar
Formally Simplɘ Jack
Default Buying headunit. Update!!!!
I'm in the market to upgrade my stock sound system, going to start with the headunit. I've decided to go with the Alpine CDE-143BT and know I would need the dash kit, wiring harness, antenna adaptor and steering wheel control. I'm getting everything via Ebay so just want to know if the parts are legit especially for the dash kit, etc.
http://www.ebay.com/itm/281199210329...84.m1423.l2649
http://www.ebay.com/itm/390682404321...84.m1423.l2649
http://www.ebay.com/itm/331019263068...84.m1423.l2649
Also, if there's any step by step write-ups that would be beneficial for me upon installation would be appreciated. Thanks.
Old Nov 6, 2013 | 10:13 AM
RandallBlackwell's Avatar
It all looks right ,but i would recommend the pac-jack from sonicelectronix for your steering wheel interface.
Old Nov 6, 2013 | 10:24 AM
Ya I'm a bit skeptical about the steering wheel interface, I here the Axxess is better and easier programming. This will be my first time installing alone so just had couple questions about installing.....which is the 12-volt accessory wire, one that turns on and off with the ignition key for the red wire?
Old Nov 6, 2013 | 11:13 AM
Just ordered everything.
Old Nov 6, 2013 | 11:23 AM
I assume you are going to be using the harness so it will connect to your factory harness with no cutting on the vehicle side. Also most Alpines i have saw are color coded wires as well. On the black connector the orange wire is hot at all times and the yellow wire is switched. there is also a switched accessory port in the fuse box where the red wire is on mine that powers my 2step.
Old Nov 6, 2013 | 11:27 AM
M4N14C's Avatar
I'm literally installing the Axxess interface on mine right now and it is a PITA. Looks like it detects the vehicle but not my head unit. Contacting tech support now...
As for your stuff, remember the antenna adapter but yet that looks right.
Old Nov 6, 2013 | 12:20 PM
What headunit are you using? That sucks, hoping it isn't too difficult to install. Is the female connector with brown wire used?
Old Nov 6, 2013 | 12:24 PM
M4N14C's Avatar
Clarion NZ503. I'm not using the female connector, my head unit has a dedicated 3.5mm connector plug specifically for steering wheel interface.
If it recognizes everything, this installation takes a minute tops. But it's held me up for the past day and a half
Old Nov 6, 2013 | 12:50 PM
Where do u connect the black and red wire? I kno it's the ground and power but what is it exactly?
Old Nov 6, 2013 | 01:01 PM
M4N14C's Avatar
Black wire to ground. Red wire to 12V accessory power which only gives power when key is in "ON" position.
Old Nov 6, 2013 | 01:49 PM
But what exactly is the ground and power? Are they wires I splice together?
Old Nov 6, 2013 | 01:58 PM
use quick splices on the radio side of your harness (the one that plugs into the head unit) connect the black to black with the quick splice and the red to red using the same method.
Old Nov 6, 2013 | 02:09 PM
I'm sure it'll be easier once I start installing.
Old Nov 6, 2013 | 02:20 PM
M4N14C's Avatar
NO you don't want to splice the ground and power wires together
Just get all the wires that need power, splice (I crimped them) to the power cable. Same with ground and all other wires.
Yes it gets easier. Just make sure to print out a schematic of all the wiring for your head unit. You don't want to incorrectly splice wires...
Old Nov 6, 2013 | 02:56 PM
NO you don't want to splice the ground and power wires together ...
I didn't literally mean to splice those two together lol, was referring in general if I splice the black wire to the ground chassis and red wire to power source. I'm just stuck on what exactly is the ground and vice versa.
Old Nov 6, 2013 | 04:03 PM
WhiteBird00's Avatar
Ungrounded Moderator
Take some time to browse through the tutorials at Basic Car Audio Electronics before you go cutting and splicing wires. If you aren't familiar with terms like "red to 12V accessory power" then it will give you a good starting education and hopefully keep you from burning your car to the ground.
Old Nov 6, 2013 | 10:07 PM
So to my understanding, do I splice the ground wire from the interface to the HU together and vice versa for the power accessory?
Old Nov 7, 2013 | 07:05 AM
You will splice the black wire from the interface to the black (ground) wire in the harness adapter. You will splice the red wire from the interface to the red wire (ignition switched power) in the harness adapter. The harness adapter has a GM factory connector on one end with about 18 unfinished wires that connect to the new head unit's wiring color-for-color (i.e. red to red, yellow to yellow, etc.).
Old Nov 7, 2013 | 08:16 AM
Ok that sounds acceptable. But now I'm a bit confused of the yellow/green wire from the interface that connects to pin 14. I'm assuming pin 14 is from the factory harness, so am I just connecting the wire to there or is there already a wire there that I have to splice together for 14? Thanks in advance.
Old Nov 7, 2013 | 08:25 AM
DamonZ28's Avatar
The wiring isn't too difficult once you get it in your hands. I always obsess about the wiring before I get new audio equipment. This year, I've installed new Pioneer head units in my 2010 Impala (which also needed a GM LAN High Speed Stereo Replacement Interface & steering wheel controls interface), and my Camaro (needed the Bose interface, which is being removed this weekend after the new speakers arrived yesterday) and both installations went very smooth. For my Impala, I connected the wiring from the harness adapter to the interfaces (mentioned above) one evening, then installed the head unit in the parking lot on my lunch hour at work - took me 30 minutes to pop off the console plate, bolt & hook everything up, and button it all back up. The Camaro took longer because I was wiring in new speakers as well.
