Double Din,,, which ones should i be looking at?
Currently i am looking at the pioneer 5600 but i see there are issues with hooking up an android phone and have it mirror whats on the phone. Are other brands better with this? Are there any models that can hook up the the steering wheel controls (yes i know there is an external box to make it work but do some radios come with this option... What else as far as features are out there.
There are no current head units that have the steering wheel control capability built-in. Almost all have the jack to connect an external adapter but they don't have it built in mostly because of the sheer number of different car models that use different signals to communicate from the steering wheel controls. Audiovox used to make 1.5 DIN units that were designed as plug-in replacements for factory radios in GM and Chrysler models (including steering wheel controls) but nobody has done that for quite a few years now.
The radio measures this value, and you can "hook" a certain function or action to that switch. Hence the term "resistive learning".
It's actually quite a nifty system : low cost, very flexible, very cheap to implement.
- Yellow is a power source from the fuse box (to supply power to the KEY resistance circuit?).
- Dark Blue is the KEY wire that goes to the headunit (the one that varies resistance, I believe. Resistance ohms are in the schematics.)
- Green is a +12v power source for the lighting that illuminates the keys
- Black is a ground
However, if your head unit has it's own system using lower voltage (whether it's 3.85V or 5V) then it must have some way of replacing the factory power input (12V) to the steering wheel switches with its own lower voltage power supply. That would mean modifying the wiring to the steering column either with an adapter or by cut and splice.
Looks great, but what not made with remotes this year, and you cant even add one, because there is no ir in the radio.
Execlon is what I have in the rest of my cars and they work great. And I cant' believe I went with Pioneer. Mind you, i'm a stereo dealer for both.
Anyway. Excelon is a great way to go, with a 2 year warranty also.
You can buy a Pioneer CD-MR70 remote that is compatible with all Pioneer wired remote capable head units if you just want a separate remote instead of using steering wheel controls.
