Car won't lock, won't release hatch, BCM issue?
I know this kind of questions was asked many times before but still mine will be different.
I have European version of 2001 Camaro V6.
- the car is possible to unlock using key fob button, but it won't lock
- it is possible to lock it ussing power door locks button on the driver doors though
- remote hatch release does not react too, not even clicks anywhere
I tried to program new key fobs (with the same P/N) but BCM does not accept them. I also tried to re-program the original key fob that unlocks the car but this one is not accepted in the BCM programming mode as well.
I looked at the BCM and haven't see any bad joints or burnt spots. The chips seem to be fine. But still there's one strange thing - in addition to the 3 original connectors there's blue-brown wire coming to the BCM box and directly welded to one spot in the circuit
I bet this isn't normal right?
There is lot of wiring and there are also some fuses located in the wiring just below the BCM - are they supposed to be there?
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
I haven't changed the battery, but I totally cleaned the guts of the original key fob. It otherwise works perfectly, but just unlocks, nothing else.
Unfortunately I don't have the hatch-release button but I'm thinking of adding one. Just to know which wire to BCM shall be grounded...?
Save the manuals!
That may be one thing to try - or switch it out with one of your new remotes to eliminate the battery from contention. You may also try using just the internals without the rubber buttons to eliminate that as an issue. (I've had remotes where something plastic/rubber breaks and the outer button doesn't make good contact with the button soldered in to the circuit board.
