Struggling with VATS bypass
May be able to power up the car without the system coming online the first time.
BTW, I would unhook the horn wire so that you can work on it without driving your neighbors up the wall...
The two things you have to do to keep VATS from preventing starting is to ground the starter relay coil output (yellow/black wire) and fix the lack of a fuel enable signal from the BCM to the PCM - that is generally done using a tuner.
That will still leave the SECURITY light on your dash. A properly implemented VATS bypass takes care of all three.
Edit: I got the alarm reset. But still nothing when the wire is grounded and I try to start it.
Edit: Welp, only got 2 starts out of that. Tried disconnecting the battery and wiring the yellow/black back in and all I hear is a knock. Tried putting the ground back in and I can't get it to start from that either.
It looks to me like I can disable the VATS on the PCM in HPTuners so the BCM will no longer comand fuel and then ground C11 from the BCM to allow the starter relay to start the car thus bypassing the stupid VATS system. I'd hate to be up on the starting line only to have a no start because a resistor decided to fail on me.
A properly wired and secured VATS bypass will last basically forever. I did one in my T/A and had it without failure for almost 10 years, and as far as I know the guy who bought the car is still running it without change another 10 years later. The bypass takes care of the security light in the dash as well, doesn't require rewiring the starter relay, and doesn't involve any PCM programming. All in all, a good solution for the cost of a couple of resistors (literally pennies) and maybe an hour of your time.
The SECURITY light in the instrument cluster is controlled by VATS. If it detects an invalid resistance value from the ignition key, the light will be solidly lit. If it fails to detect any resistance value, the light will be flashing. If the failure occurs while the engine is already running then the system assumes a fault and will still allow the car to be restarted. Otherwise, the system will disable both the starter relay and the fuel enable signal from the PCM effectively preventing the car from starting.
Since your car continues to start, the system must be considering the wrong resistance as a system fault. However, you must get it fixed before you disconnect the battery for any reason because when you reconnect the battery it will no longer be considered a fault and your car won't start.
Solution: Determine the ohm value of the reistor key so you can purchase the correct resistor(s) and either solder onto the PPL/WHT and WHT/BLK wires or cut the lead which has the two white wires, disconnect the connector and solder the resistor(s) between the two white wires and plug it back in. Check the ohm value of the connector prior to connecting it back up to see if it matches the key and if so then you should be good to go.
Still no start? Is the starter relay good and are you getting 12v at the power side of the relay when keyed on to start? If the VATS bypass didn't work and you're not getting a signal to the relay YLW/BLK wire from the BCM then you could have a bad body control module. If everything is working as it should then when you key it on to start you should have 12v at the purple wire coming from the starter relay which goes to the starter solenoid and if so then I'd start looking at your starter.
Otherwise, either your resistors aren't making a solid connection to the two wires or there is a break in one or both wires between the steering column and the BCM.
