Help with disconnecting Monsoon head unit
What's wrong with your radio? Do you really need to send it out? The Monsoons have a few gremlins that are easily solved at home.
Volume control **** not working correctly, especially when lowering the volume
Lights on two CD player buttons (play and eject) have gone out
This is a burned out light bulb. Easy to change yourself with a screw driver and you can get a new one from eBay for $15-25. There are threads here instructing on how to do this.
More burned out bulbs - but these are on the circuit board behind the buttons. This is a little harder and require soldering to replace. Is this something you can do? We have threads on this, also.
^ If you want to send the radio out, you can get the bulbs taken care of, but I would definitely do the volume control yourself. If you have someone "fix" it, you'll get a used part from someone else's radio and end up in a worse spot.
This is caused by dirt in the volume control. If you pull the **** cap off, spray electrical contact cleaner down the shaft, and spin the ****, it will clean things out and should fix the problem. I recommend using MAF cleaner for this since it is a type of electrical contact cleaner safe for plastic.
I hadn't seen about the simple bulb replacement for the LCD. I'll have to look (link?).
Does the volume **** just pull straight off?
Yep. Like the antenna wire, it may stick a little the first time, but you just pull it straight off the shaft. Once off, you can use a spray straw to direct cleaner down the **** shaft. (Inside the **** assembly are stacked plates that turn against each other and create varying electrical signals. These plates get dirty and cause the interruptions - the unit can't tell if you are turning the volume up or down. Once that dirt is off, all is good. It may take multiple cleanings.) I took one of these apart once to investigate. Each time this subject comes up, I kick myself for not taking a picture of the insides!
If you can't get a grip with your hands, using needle nose pliers and levering against the radio chassis is a good way to do it
