only rear trunk speakers work
my stereo is an all stock monsoon system and for some reason, one day all the speakers stopped working except for the 2 rear trunk speakers. does anybody know what went wrong here? i removed the stock CD changer... not sure if that caused it? thanks.
If you have a multimeter, check for power at the amp. Then check for signal from the head unit to the amp, then check for output at the amp. Then check for signal at the speakers.
That should cover most/all of your bases as to why this would happen.
I'm sure there's a better way, but that's what I would do.
