Power Antenna pops up w/Aftermarket Headunit
Old 09-08-2017, 08:52 PM
michaelhawk's Avatar
Default Power Antenna pops up w/Aftermarket Headunit
When I bought this car I replaced the power antenna with a brand new GM unit. Yes, I spent a good dollar for the part, but I wanted an original OEM antenna. And it works perfectly, all the way up and down, no noise or issues while using the stock head unit.
Last year I bit the bullet and installed a double din JVC headunit w/External sub. Wired up everything carefully and correctly. The only issue I have is the antenna up about an inch sometimes after the car if shut off. I can manually push it back down.
Although I never use AM/FM, if I do, the antenna will go all the way up and all the way down as expected.
When I use anything else (XM, Bluetooth, Pandora) is when I find the antenna popped up when I've shut the car off. See attached pic.
For some reason, I assume, a brief signal gets sent to the antenna.
Any thoughts on why this happens?
Attached Thumbnails Power Antenna pops up w/Aftermarket Headunit-img_0641.jpg
Old 09-09-2017, 11:06 PM
Copy & Paste Moderator
VIP1's Avatar
I put a switch inline (the pink wire) so it stays down unless I want it up.
Old 09-10-2017, 06:50 AM
midnitez's Avatar
This is exactly what I did.
Old 09-10-2017, 06:40 PM
I thought about doing that, but would be nice if the antenna operated as expected with the aftermarket headunit.
Thanks tho, I'll keep it in mind.
Old 09-11-2017, 02:13 PM
1999nbmZ's Avatar
You could wire the blue wire from the jvc through a relay first, before it powers the antenna wire. If there's a small voltage resting on the blue wire when you're not listening to am/fm, this would allow the antenna control wire to truly rest at 0 volts.
Might work, might not. But at least give it a shot. If it doesn't work, then a manual switch as stated above may be a good option. The relay would basically do the same thing, just without you having to flip a switch every time.
Best of luck, post up if you have any other questions.
Old 09-11-2017, 09:33 PM
Thanks for the idea...I think your on to something here.
Any thought on what kind of relay for this?
Also, I re-read the instruction page for wiring, and i see there is a box of some sort JVC pictures with the power and switched power wires running through, see pic bottom right corner. I dont know what that box is supposed to be.
Attached Thumbnails Power Antenna pops up w/Aftermarket Headunit-jvc.png
Old 09-12-2017, 07:19 AM
Ungrounded Moderator
WhiteBird00's Avatar
That's just a generic representation of the car's electrical system. The fuse box depicted close to the battery represents the junction box under the hood and the other two fuses represent the fuse panel at the end of the dash. They don't represent anything specific to the JVC setup.
Old 09-12-2017, 07:39 AM
Thanks, that helps.
So I think I'd be looking for a 12v Relay with a delay. I'll start playing around with this later in the week.
Old 09-19-2017, 07:44 PM
This is what I came up with. Reply with a delay, and OEM male and OEM female end connector to make this thing plug and plus without cutting my harness.
Seems to work well! During my testing the antenna never went up, not even a little, when NOT using AM/FM.
When selecting AM or FM, a 6 second delay and the antenna climbed all the way up. Upon selecting something else or shutting the car off, the antenna dropped all the way down.
Time will tell tomorrow with normal driving and all to verify the antenna NOT going up at all, when using Bluetooth or Pandora APP.
Thanks for everyones ideas.
Attached Thumbnails Power Antenna pops up w/Aftermarket Headunit-img_0690.jpg   Power Antenna pops up w/Aftermarket Headunit-img_0688.jpg   Power Antenna pops up w/Aftermarket Headunit-img_0694.jpg
Old 09-26-2017, 01:58 PM
Here's an update on my little gadget: It Works!
Not once have I found the antenna popped up at all.
Quick Reply: Power Antenna pops up w/Aftermarket Headunit
