Wiring under dash/steering column question
Im in the process of getting my factory alarm back to working and a shop did a fucked up job on the wiring and I’m left with fixing the wiring. The wires I first noticed are in an Orange casing as just dangling, are these for Vats? And for some reason I have a brown wire I can see the splice in a red wire but it goes nowhere, literally is isn’t connected to anything. The brown wire is coming from towards the fuse box area.
Brown wires under the dash usually are for lighting - they carry power whenever the parking lights or headlights are on.
Now soldering the purple/white and white/black wires together with the correct resistor in between is how VATS bypasses are done. Again, if they're just shorted together than VATS will be a problem.
I still need reconnect a wire together (forgot the 2nd butt connector) before I can reconnected the battery and fire it up. But I just don’t know why I have the orange wire going up the column and also have this ****. I guess I won’t find out until I go to start it up lol
I’ll try to post pics if I can make a choice on which site to host my images.
Now here is where it gets interesting, wtf is this orange wire coming out of the steering column? I thought there was only 1 orange wire in the column for VATS.
If you need a better pic I can get a better pic, but I think you get the idea lol
Update: so I was checking the features with the car running and with it no running of lights and accessories; my windows work, all lights work and now my stereo finally stops resetting itself (it used to reset the stereo every time I shut the car off) but now the door locks won’t lock when trying to use the switch on the doors. I can hear a clicking at the BCM but the locks don’t engage. I’ll check fuses tomorrow.
