Optima Redtop
Old Aug 1, 2018 | 11:42 PM
Zonie's Avatar
Default Optima Redtop
Any recommendations on the best model? Fitment is not an issue, Its an LS3, from what I,ve researched it needs a minimum of 720 cold cranking amps.
Old Aug 2, 2018 | 12:35 AM
eb110americana's Avatar
Why not yellow top? They have better resistance to discharging.
Old Aug 2, 2018 | 12:43 AM
Zonie's Avatar
Which is good if your running a lot of accessories or a killer stereo, the redtop from what I've read has a stronger starting burst and has a faster recharge rate, my LS3 is in a 67 Nova. My main concern is how many cranking amps I should buy.
Old Aug 7, 2018 | 08:32 AM
Need4Camaro's Avatar
Don't go with Redtop, I'm serious by this too. I've had to replace 3 of them within a 5 year period. They're great for cranking but in any situation where they receive constant discharge and the car sits without being used for more than about 2 - 3 days...they die FAST.
Yellowtop is a very strong starter and is much more resilient to discharging which will make it last alot longer.
Redtops don't like alot of draw, they have a strong BURST but once thats done they lose their integrity quick. Yellowtop is a deep cycle battery meaning it can be drained heavily without damaging its lifespan.
Old Aug 7, 2018 | 09:41 PM
Zonie's Avatar
Well I think you convinced me Need4Camaro, which one are you running?
Old Aug 8, 2018 | 10:08 AM
Yellowtop. Cranks my car just as hard and effortless as my redtop did.
If you really want to make a difference in the charging system, 0 Gauge Battery cables, Truck Starter (which should be a mandatory upgrade for all LS1 owners), and High Amp Alternator. I've done all 3, its a big difference trust me.
Redtop would be great for like a Utility Vehicle or a Vehicle that makes alot of shorter trips and rarely sees down time.
Old Aug 8, 2018 | 11:06 AM
Zonie's Avatar
I have 1 gauge cables, the engine/trans combo is a connect and cruise and Pace Performance recommended the 110 amp alternator, is that considered high amp? What yellotop do you have, mine is trunk mounted, from what I have read the LS3 needs at least 720 cca. Does this sound about right?
Old Aug 18, 2018 | 06:22 PM
Phoenix'97's Avatar
I had three relatively new starters end up cracking their housings. Upon researching what causes this, it was suggested that a low charged battery could result in overextending the gear. The battery I was using at those times was my optima red top which I had been trickle charging after every winter allowing me to extend it's use for up to ten years. The battery finally could no longer hold a charge and this is when I started going through starters. Supposedly the cranking power of the optima battery, even when low, is what could have lead to cracking the starter housings. I am now using a regular Delco battery which should last twice as long with trickle charge maintenance on it and we will see how the starter holds up.
I was sold on so much marketing when I was younger but now I realize the value of the advice I was given by mechanics in the past who disagreed with what I was doing with my car back then, keep her stock...
Old Aug 25, 2018 | 09:12 PM
JakeFusion's Avatar
Super Hulk Smash
Yellowtop works well for me.
I've also had success with DieHard Platinum and Odyssey.
